R60 Removing R60 S grill to install a badge
Can someone confirm how to remove the front grill on the S? I need to get behind it to bolt on a badge. I see that there are 4 bolts on the plate on top, but am not sure what to do next, as it seems I may be missing some tabs or other bolts.
I don't want to break anything!!
You pull from the bottom right corner towards you. There are 8 or so clips or so holding the bottom part. Getting the clips back is more of a chore. It requires a bit of oomph. Had to take grille off when I did my lights.
Just need to be sure.
squawSkiBum
Oct 2, 2015 09:21 AM
Drivetrain removing heat shields for turbo cat ?
rckrzy1
Aug 11, 2015 06:06 PM
