JCW GarageInterested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
Great good luck with that , please let me know what you think?
I hope that the results are as you expected .
The first response should be improved and I hope that there is no
turbo lag.
turbo lag.
sorry guys.. my E55 AMG is still on the lift... Once it comes down. up goes the Clubbie.
I have enjoyed the AMG cars and have been surprised by the wagon by a sweater vest wearing lady at the drag races where she laid down mid 11sec passes and was the sweetest lady you'd never though could drive and cut killer lights too!! Her hubby drove a SC Jag that was equally fast, they were regulars at the track... The E55 sure is a Gem that I am sure is missed in the lineup, not that the 6.3 is bad, it just isn't as fast yet probably better handling from the factory... What is your assessment since you have them?
If I understand it right you have an 09 JCW clubman?? Measure the inside diameter of the turbo inlet on the turbo that is on the car now & the new billet turbo. If the new turbo is 0.50" smaller then you are heading in the wrong direction. I've been doing some heavy duty tuning for the past 2 yrs. I have a pretty good idea what works and what doesn't.
http://www.flickr.com/photos/20691767@N06/8250376026/
http://www.flickr.com/photos/20691767@N06/8249309659/
Take a look at the intercooler.. I seem there is no way to level it.. are we installing it wrong..
http://www.flickr.com/photos/20691767@N06/8249309959/
And finally 1st drive yesterday.
So couple of quick thoughts. Only spent about 20 min there with the car. did not pick up yet..
[Mr.Cooper] have not time 0-60 as I was the first drive around the block to make sure every thing is running right.
nor has it been in dyno yet.
- the Akra DP is freaking loud. the pop and bubble is crazy. I feel alitte embarrass driving it around. I feel like a "ricer". Maybe I am too old for that. And using Stock JCW exhaust.
-the turbo spools pretty quick. no turbo lag.
-even with OS Giken LSD / Clutch the tires spins in first , and little in second gear. using PSS tire. I have another set of wheels with hankook RS3. will try that.
- blistein PSS10 is very smooth. M7 coliover are rougher.
as of tuning the car.. I was using the stock mapping of Alta AP.
Started on Stage 1.
boost at 20.4/ held at 17.9
the exhaust was popping crazy.
Stage 2
boost at 20.8 / held at 18.8
exhaust same.
stage 3 at 22.3 / held at 20.6
exhaust calm down on popping.
