R56 Determing What Service is Required
Old May 24, 2012 | 09:10 PM
azn_redneck's Avatar
azn_redneck
The Mini says it needs service...but what service? The owner's manual seems to indicate that you can use the onboard computer to determine what service is required, but the information available doesn't match what the manual claims is available. The only things available through the onboard computer is to set the date and time. Is there a way to determine what service the CBS is saying is required?
Old May 25, 2012 | 06:00 AM
klricks's Avatar
klricks
The procedure is in the manual SERVICE REQUIREMENTS section page 53-54 (PDF version). (The printed version page # may be off by a page or 2)
Be sure to follow the instructions exactly..... especially step 1 were it says to turn the ignition on.
Old May 25, 2012 | 07:04 AM
schatzy62's Avatar
schatzy62
You are using the "wrong" buttons and "instructions" the manuals are very good at giving directions on how to see what is up if you use the correct instructions.
Well that is if your manual has all the pages. I have seen manuals that are missing complete sections.
Old May 25, 2012 | 05:28 PM
azn_redneck
Yep, that's the part I missed - had the key in, but engine wasn't running. It says I need brake fluid service. I thought they did that when I had it in to replace the water pump - maybe they forgot to reset it?
Old May 25, 2012 | 06:43 PM
ChrisTKD's Avatar
ChrisTKD
Brake fluid would be unrelated to the water pump recall.
Old May 25, 2012 | 06:54 PM
jcauseyfd's Avatar
jcauseyfd
With a 2008, I think you are probably outside the included maintenance program. So you would have to instruct them and pay for the brake fluid flush.
Old May 25, 2012 | 06:57 PM
MCS Fever's Avatar
MCS Fever
It goes something like this:
Oil change 1 year or CBS (CBS does not get reset at 1 year).
Brake fluid 2 years or CBS
Micro filter 2 years
Air filter 2 years or every 2nd oil change or CBS
Tires 6 years
Spark plugs 60K
Auto tranny sevice 100K
Oxygen sensor 120K
Coolant N/S ("Long-term rated. Change at system repairs ony").
V-belt N/S
Fuel filter N/S
Power steering fluid N/S
Kimolaoha
Jul 5, 2023 01:04 PM
stevepsd
35
Dec 6, 2022 03:22 PM
boostedhaze
Sep 2, 2015 07:56 PM
Aug 19, 2015 12:51 PM
