Will these wheels fit on my R53??
I may be getting a set of Autostrada Modena wheels. I just need confirmation that these will fit and won't rub.
16x7
Offset 39mm and 42mm
4x100
Hub bore: 57.1mm
They look like this..
Any help will be great!
16x7
4x100
Hub bore: 57.1mm
Yes, they should work. I think you might need hubcentric rings because of the center bore size. I think MCS is 56.1. I am not sure if the 57.1 will be an issue or not. I am sure others can verify. Other than that i dont think you will have any issues rubbing.
They will look great on a MCS!!
yeah that would be a small ring
plus the lugs should help center the wheel to the hub.
A nice stretched tire would go nice with a nice lowered suspension.....nice stance flush look!
Good luck....post pics if you go with them wheels!
plus the lugs should help center the wheel to the hub.A nice stretched tire would go nice with a nice lowered suspension.....nice stance flush look!
SosoMINI
Nov 22, 2015 03:17 PM
Mini'mon
Aug 16, 2015 04:15 PM
Aug 12, 2015 01:24 PM
O4mcs
Aug 6, 2015 05:42 AM
