R56 belts/chains non-S
Old May 21, 2012 | 07:33 PM
eaglebeagle's Avatar
eaglebeagle
belts/chains non-S
I know its here somewhere, but search isn't being friendly
what does the '08 non-s have for belts/chains and when should i change them?
thanks!
Old May 21, 2012 | 07:40 PM
Porthos's Avatar
Porthos
Chain should be fine for well over 100k. Belts if I am not mistaken are between 80 and 100k.
Old May 21, 2012 | 07:53 PM
eaglebeagle
good good, but can you be more specific- what do i have that i need to worry about(non-s)
Old May 21, 2012 | 08:29 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
On an R56 MINI we recommend replacing the drive belt every 50k miles. Otherwise change your oil every 5k miles, and then we also recommend replacing the engine air filter every 30k miles, or use a K&N filter and just clean it. Then replace the A/C microfilter once a year. and replace the spark plugs every 100k on a non S.
Old May 21, 2012 | 08:31 PM
eaglebeagle
gotcha. so i do have a chain for timing, that SHOULD last the life of the car. just the acc belt is all i need to worry about for belts thens.
Old May 22, 2012 | 05:04 AM
schatzy62's Avatar
schatzy62
All of this info is in 100's of threads around here on the forum. So much so that you dont even need to search just look at the first page of the different sections and you will see you answers.
scottselk
Jul 20, 2019 06:43 AM
ej
Nov 17, 2015 09:21 PM
silence2-38554
Sep 24, 2015 05:34 AM
Ryan Caballo
Sep 4, 2015 12:20 PM
Shelly Cooper
Aug 10, 2015 12:05 PM
