New Window Motor runs backward???
Old May 17, 2012 | 12:51 PM
movieman's Avatar
movieman
So, I just installed a new window motor and it runs backward...up is down and down is up. Why/how do I fix this?
Old May 17, 2012 | 12:58 PM
MSFITOY's Avatar
MSFITOY
reverse the polarity?
Old May 17, 2012 | 01:06 PM
movieman's Avatar
movieman
how?
I can't figure out how to get the wiring connector apart.
Old Oct 5, 2013 | 03:16 PM
McNut's Avatar
McNut
Props to "Paul P" for posting the solution on youtube.
1. Take the regulator assembly out of the door. :( You can just take out the front part with the motor on it if you're lazy.
2. The metal motor housing is secured to the plastic gear box with 4 small screws at the base of the housing. Remove them.
3. Slide the housing about half way off the motor, rotate the housing around the motor's axle 180 degrees, and slide it back on.
4. Reinstall the 4 screws.
5. Reinstall the regulator assembly in the door.
Voila!
surfblue
Oct 24, 2018 01:20 AM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
Dec 23, 2015 10:36 AM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
