Swapping brake pads for track duty question
I just got my EBC yellows for track duty but not sure if I need to do anything in particular before swapping them. I plan to only use them for track and swap back to OEM afterwards each time. Does this mean I have to keep purchasing a new set of brake sensors each time i do the swap? Or is it just a simple swap of the pads and plug the current brake sensor back in afterwards?
edit: oh yeah, it's a '11 R56 if that matters
Another solution is to cut the sensors off, close the circuit by connecting the wires, and call it a day. If you're on top of what condition your pads are in, there is no need for sensors.
If your brake wear sensor is still in tact (not showing a warning on the dash) then there is no need to cut it an splice the wires together. Just tie it up away from any moving parts that could snag it or wear through it.
I was wishfull for a little better performance than that out of them. I am used to Carbotech XP 10s but lost my source and was hoping I could find something a little less expensive.
Are you looking at some other pad for the future?
Since I'm only using the yellows on track (i'm swapping them out/in from OEM), I don't plan to purchase any new pads in the near future considering i only do a couple track days a year (4-5 tops). But I definitely considered the Carbotech XP 10s before jumping ship on the EBC yellows. I wish PFC or Axxis made pads for our car; if they did, I'd definitely get a set from either of those companies since I loved them on my E46.
penguinhomey
Aug 17, 2015 01:33 PM
