P0171 Code
Old May 4, 2012 | 07:28 AM
Martin Brenneke's Avatar
Martin Brenneke
P0171 Code
I was drivinghome and going up a hill under full throtle and the code P0171 showed up . Car a 2005 JCW ran well after clearing code. Does anyone have an Idea as to what might have caused the code? BaD GAS, WATER IN THE fuel ,to much ethanol in fuel. Code is SYSTEM TO LEAN. aNY IDEAS WOULD BE HELPFUL.
Old May 4, 2012 | 07:57 AM
BMUN8IVE's Avatar
BMUN8IVE
I could have sworn I had the same code thrown, but it turned out to be the cam timing sensor.
Old May 4, 2012 | 09:20 AM
proximo's Avatar
proximo
If it's reporting a too lean condition, it means there is too much oxygen in the system. This could be a bad/dirty MAF sensor, a leak in the system after or near the MAF, or a clogged injector/filter/fuel line.
Old May 4, 2012 | 09:38 AM
ThumperMCS's Avatar
ThumperMCS
R53's don't have MAF's...
Old May 4, 2012 | 09:42 AM
proximo's Avatar
proximo
Sorry, MAP sensor.
Old May 6, 2012 | 05:43 PM
R53fort's Avatar
R53fort
my 04 had the same fault for a while. i took it it in at work and used the smoke leak tester and oddly found that the o-ring for the oil fill cap was leaking air into the system. i replaced the cap and have not had the light come on yet.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
olson187
Sep 18, 2015 10:26 AM
Mini Hooper
Sep 17, 2015 01:58 PM
Enjoytheride
Sep 17, 2015 12:10 PM
