Suspension Added 22mm Alta Sway Bar
Old May 1, 2012 | 07:01 PM
zamfield's Avatar
zamfield
So I added the 22mm Sway Bar from Alta today.
It's set on the middle setting but I think I'm going to put it on the stiffer setting as I don't feel the difference I thought I would.
It's tighter going through the twisties... Less roll but I feel it needs a little more.
Look good though!
Old May 1, 2012 | 08:18 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
That does look good. Hopefully they are powedercoated now. My alta 22mm bar is flaking paint with rust underneath, but it is 6 years old now.
Old May 1, 2012 | 11:19 PM
Eric_Rowland's Avatar
Eric_Rowland
FWIW, I'd wait a week before going to the stiffest hole. Only takes one throttle lift to ruin your day.
Old May 2, 2012 | 05:10 PM
zamfield's Avatar
zamfield
Ok, took around some serious twisties today... I'm sold!
Brakes? Who needs brakes?! LOL!
Old May 2, 2012 | 05:36 PM
boxter4ever's Avatar
boxter4ever
hi,i track my mini,i just want to say respect that bar!! on full stiff!!
Old May 2, 2012 | 06:14 PM
zamfield's Avatar
zamfield
I'm all for full stiff where holes are concerned!
Think I'll run it at the Deagon this weekend and see how it stands up, on the middle setting.
Cheers!
Old May 2, 2012 | 07:42 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
I find my car to be neutrally balanced with the bar at full stiff. Powered understeer and lift oversteer is fun.
I ran dozens of hot runs of the Dragon with it at full stiff. It just takes commitment and a gps road map co-driver (shows next few curves). The middle setting would probably be best for twisties. But there are none here, so full stiff works best with all of Nebraska's 90° turns.
Old May 2, 2012 | 07:55 PM
ERIK06MCS's Avatar
ERIK06MCS
I was tempted to get a rear sway bar but I quickly realized how worthless it would be in Chicago. I imagine much like Nebraska, all 90° turns but only with stop lights every 1/4 a block and red light cameras so you can't even turn on red anymore :-/
Looks good though zamfield
Old May 3, 2012 | 05:29 AM
buzzsaw's Avatar
buzzsaw
Felt the same way until I installed one. Then I discovered along with negotiating the
twisties the added benefit of dramatically improved accident avoidance and lane change capabilities.
Old May 3, 2012 | 05:59 AM
zamfield's Avatar
zamfield
Agreed... Had to avoid a "chunk" of road kill yesterday and zipped right around it with no trouble!
I will say that if you drive primarily on straight highways, you'll not feel the Benefit of a bigger rear sway bar.
rtk90
Aug 29, 2019 09:08 AM
dropnstylez
Oct 29, 2015 08:57 AM
Suspension Products
Sep 3, 2015 09:41 AM
Suspension Products
Sep 2, 2015 10:32 AM
Hippiehobbit267
Sep 1, 2015 06:13 PM
