Lubricate wheel hub
Old May 1, 2012 | 04:26 PM
MiniKJ's Avatar
MiniKJ
Lubricate wheel hub
Hi fellow MINIers:
Howdy. I want to ask those who rotate their own tires besides their rotisserie chicken. Do you put white lithium grease around the outer side of the hub before reinstalling the rims? When I rotated tires last time, the rust gave resistance while pulling out the rims. I'm not certain if the white lithium grease is the right stuff to put there.
Appreciate your help in advance.
Old May 1, 2012 | 04:48 PM
ZippyNH's Avatar
ZippyNH
I use a trace of anti-sieze...the hi temp stuff.
Old May 1, 2012 | 04:50 PM
GLN305's Avatar
GLN305
This^...also on the rotors when you swap them.
Old May 1, 2012 | 05:00 PM
Capt_bj's Avatar
Capt_bj
yes
anti-seize
not a plain grease
VERY little - do not over apply
clean any rust spots with emory cloth b4 you apply
Old May 1, 2012 | 06:11 PM
ZippyNH's Avatar
ZippyNH
+1 do not use grease....when you do lots the braking (or even the heat from the hub) the greae can liquefy, and drip away....possible danger in braking, and it will not be able to do its job.
I use permex anti seize...i bought a small jar with a brush, but you can usually find it in small ketchup sized packs (way overpriced though) by the cash register at most auto stores. The jar is about a lifetimes worty for a home mechanic, but good to have around.
Old Feb 5, 2017 | 04:46 PM
coopspeed's Avatar
coopspeed
Yes, a little white lithium grease around the hub ring. Not enough to drip.
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
TOMSR53
Aug 26, 2015 10:18 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
