Ignition key problem
Old Apr 30, 2012 | 05:01 AM
gear-head's Avatar
gear-head
2002 MCS: I replaced the key shell because the logo had fallen off and the key itself was a scratched up mess.
Now, the Door lock/unlock works, but the engine won't start. All the lights come on, but it won't start. I've tried all the voodoo combinations of button pushes but nothing
Interestingly, if I start the car with the Valet key, remove it, and put the remote key in, it DOES start. But, leave it out for a while, and it goes back to not starting again.
Any ideas?
Old Apr 30, 2012 | 02:04 PM
Eric_Rowland's Avatar
Eric_Rowland
Sounds like you didn't transfer the chip the ECU uses to verify you're using a valid key. Try holding the old key next to the ignition while starting it with the new key to verify.
Old Feb 22, 2013 | 01:19 PM
shorn's Avatar
shorn
That's exactly what happened to me... And what I didn't do. In fact, I almost threw away the old shell after transferring the electronics and actual "key". Only much later (and a lot of gut wrenching and head scratching) found the RFID chip in the back of the old shell. Rather than transferring the chip I just reused the old shell back with the new shell front, with its MINI emblem. And now she cranks!
StillK
R55 :: Clubman Talk (2008+)
Dec 7, 2022 08:19 AM
missinmyjeep
Aug 22, 2015 07:13 PM
coachvminis
Aug 17, 2015 01:42 PM
speedbird_1
Aug 15, 2015 04:44 PM
skippermini
Aug 13, 2015 06:13 AM
