215/45ZR17 Sumitomo's fit a crown spoke?
Old Apr 29, 2012 | 07:16 PM
NJ Mini's Avatar
NJ Mini
Recently started using my Cooper S with Crown Spokes for a 50 miles each way commute and I still have the run flats on. It's killing me and the car. My question is, I have a set of Sumitomo HTRZ III's, sized 215/45ZR 17 from a previous car with only 5K miles on them, will they fit the crown spokes I currently have? The current tires are 205/45-17's. I know the 215's are a slight bit wider, but I would suspect they would fit. Anyone know for sure?
Thanks in advance.
Old Apr 29, 2012 | 07:19 PM
Blackbomber's Avatar
Blackbomber
I had crown spokes on my first gen when I got it. I believe they are 7" wide. Anyway, lots of people do just what you propose, and are happy with the outcome. I ran the 205's, and there seemed to be plenty of room for one size up.
Old Apr 29, 2012 | 08:45 PM
ricbow's Avatar
ricbow
i have z 111's on my crowns , work perfect.
Old May 2, 2012 | 12:50 PM
Alex@tirerack's Avatar
Alex@tirerack
215/45R17 will work!
Old May 5, 2012 | 01:31 PM
NJ Mini's Avatar
NJ Mini
Thanks Alex and to the others that posted as well.
Also, Alex, what do you recommend for fixing flats since I won't have a spare?
Old May 8, 2012 | 12:33 PM
Alex@tirerack
You can carry a extended mobility kit, like the Conti comfort kit. I also suggest carrying a plug kit with you. If your car has the sensors, it will be very difficult to get the sealant into the tire and wheel, and you will certainly render the TPMS sensor unusable. Plugging and topping up the air pressure would be your best bet. Many owners invest in a compact spare tire and wheel to carry with them for additional convenience.
SosoMINI
Nov 22, 2015 03:17 PM
TJANK
Aug 24, 2015 06:11 PM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
