How tough are BMW Wheels
Old Apr 25, 2012 | 08:47 PM
jimalameda's Avatar
jimalameda
So tonight I'm going to girlfriend's house in the Oakland Hills, raining, kinda dark and avoid two pots holes on the left side but too late I hit a pot hole on the right . I have black crown point wheels on run flats-felt like I hit something big with the run flats. Are the wheels tough and strong-weight on these? Anyone know. Acourse it was raining and the pot-holes fill with water. I guess I'll find another street to go up....but that one wheel. I wonder if it is shaped like an egg.
Old Apr 26, 2012 | 10:20 PM
jimalameda's Avatar
jimalameda
No thoughts about wheels and potholes...Anyone Ferris Bueler!!
Old Apr 27, 2012 | 09:58 AM
Jim Michaels's Avatar
Jim Michaels
Okay, I have some thoughts about wheels/tires and potholes; some of which may even be true.
Most cast alloy OEM MINI wheels are apparently fairly strong, and the run-flats have stiff sidewalls, which should provide more pothole protection than non-runflats. Also, the wider (taller) the sidewall, and the more air pressure in the tire, the less likely hitting a pothole is to bend a wheel.
The probability of bending a wheel also varies with the speed or force of impact, and the configuration (including depth) of the pothole.
You can do a rough check for roundness at home; first by eye-ball, then by measuring all around the rim from the exact center of the hub. But if it's barely bent, even careful measurements may not detect it. A tire shop can detect even slight bends, however.
Also carefully check your tire and suspension.
Old Apr 27, 2012 | 02:01 PM
Mini2na's Avatar
Mini2na
MINI wheels are heavy and tough. Hit a few potholes myself and no damage. Can't say the same for some aftermarket wheels.
Get yours checked if you any question about them. Wheels are pretty important. They are where the rubber meets the road.
Old Apr 27, 2012 | 02:18 PM
jimalameda's Avatar
jimalameda
I figured the BMW wheels would be tougher then ones purchased and made from X&Y alloys. Being a mechanical engineer, I have seen some of the manufacturing processes in Mainland China.
woodstudio
Mar 15, 2020 08:28 AM
theblackfalcon
Oct 11, 2015 09:49 AM
Zettinger
Aug 25, 2015 04:04 PM
