R50/53 IE fixed camber plate toe
Old Apr 25, 2012 | 07:22 PM
micromini234's Avatar
micromini234
Well i'm wondering what you guys think the best toe is for front and rears, seeing as how an alignment from mini is $200!! I cant exactly redo it a lot everything is stock and the ride height will be stock because i'm cutting the brackets on the shocks. As well CT has pretty curvy road and hills, so i'm looking for street performance, less under steer and better cornering, fair tirewear. Anything would be really appreciated *this a 2003 non S
Old Apr 26, 2012 | 07:24 AM
dw1's Avatar
dw1
Some alignment generalities, not specific to a particular car. If you want to reduce understeer, you can consider some toe out for the front, a less toe in at the rear (sometimes you end up with toeing out the rear, but that can be unstable under the brakes). Tire pressures will affect balance, more pressure raises the effective spring rate but sometimes also can create more grip from the tire so you need to experiment there. You can add some negative camber to the end that is breaking away first. Have fun experimenting, alignment can be done pretty easily at home with very simple tools (string and jackstands to measure toe, a plumbob and scale for camber).
Old Apr 26, 2012 | 07:38 AM
quikmni's Avatar
quikmni
You should be able to find a good tire/alignment shop that will do a full 4-wheel alignment for about $100.
You do not state what year your car is so you may or may not be able to adjust the rear camber.
Going along with what dw1 has suggested I would suggest:
Zero to slight toe-out in the front (0 to -0.07 degrees per side).
Zero toe in the rear. Around -1.0 to -1.5 camber in the rear.
I would also suggest a 19mm adjustable rear sway bar to compliment the camber plates and alignment.
Old Apr 26, 2012 | 04:18 PM
micromini234
Oh oops I edited it, its 2003 non ,so I already know its not adjustable, yeah I was planning to get a 19mm swaybar too, In the rear you suggest 0 toe in, does 0 toe in have a negative effect on cornering c controllably ?
Old Apr 27, 2012 | 03:54 AM
william smith6161's Avatar
william smith6161
Sounds good to me
Old Apr 27, 2012 | 07:34 AM
quikmni's Avatar
quikmni
I have not noticed any issues with zero toe in the rear.
You might notice slight handling differences with toe changes in the front.
OEM setting usually have toe-in (positive angle) because this provides straight line stability. Toe-out makes for faster turning response but the car will tend to wander very slightly on the highway (tend to follow road irregularities a little more) but I have not found it to be an issue. My 2012 Subaru Outback wanders much more on the highway than my 2006 Mini with a little toe-out.
dropnstylez
Oct 29, 2015 08:57 AM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
veevsato
Sep 15, 2015 06:04 AM
Sep 11, 2015 01:15 PM
Sep 3, 2015 02:06 PM
