R56 Changed the oil and now it knocks!?!
Old Apr 14, 2012 | 07:15 PM
Everyday I'm Motorin's Avatar
I changed the oil last weekend and now the engine knocks on cold start up. It continues to knock for a few minutes in the mornings and stops a quarter mile or so from the house. It won't do it when it's warm. I used factory authorized Castrol STP European Formula 0W-30 and a genuine MINI filter. It didn't knock before the oil change. What could I have done to cause this? It can't be a coincidence.
It threw a CEL. OBDII scanner said it was a knock sensor. I reset the code and it's stayed off but the engine still knocks.
Old Apr 14, 2012 | 07:40 PM
Llanrhaeadr_Cymru's Avatar
Llanrhaeadr_Cymru
Double check that your threaded oil fill cap is installed properly. My MINI had a check engine light/rough initial idle/code much like yours. The service advisor also warned me to be sure that the dip stick was well seated too.
Hope the solution is as simple as this...
Old Apr 14, 2012 | 07:46 PM
I'll look at that in the morning. Thanks for the tip.
Old Apr 14, 2012 | 11:14 PM
cbclubS's Avatar
cbclubS
Is it the "death rattle"? Google or YouTube it, either way 09 should be a warranty issue, right?
Old Apr 15, 2012 | 06:19 AM
drsimmons's Avatar
drsimmons
As well as the dipstick being pushed all the way in also
check to make sure the oil cap is on firmly. If either of
these two things are not correct you can get a CEL and
rough run.
Double the oil filter housing check also. Should be able to
feel around the base and make sure it's not cocked eyed.
Make sure there is no oil seepage from the filter housing.
Very stupid question but you did put oil in it, right!
Old Apr 15, 2012 | 08:17 AM
minimini482's Avatar
minimini482
Make sure you have enough oil in there too. Mine knocked a bit the first time I did an oil change although not enough to throw a cel. I just needed to add a little more oil and it quieted down. Hope it's a simple fix for ya.
Old Apr 15, 2012 | 04:50 PM
ellinara's Avatar
ellinara
Mine knocked when I accidently overfilled... check oil levels as well
Kimolaoha
Jul 5, 2023 01:04 PM
sprp85
Aug 22, 2015 06:16 AM
AoxoMoxoA
Aug 21, 2015 09:15 AM
elightbo
Aug 17, 2015 01:50 PM
FLYM1N1
Aug 16, 2015 01:17 PM
