Suspension My first mod...
Old Apr 13, 2012 | 09:31 AM
ARCooperS's Avatar
ARCooperS
My first mod...
So I am thinking that my first mod will be the WMW Suspension Package
  • TSW Springs
  • HSport Rear Lower Control Arms
  • HSport Rear adjustable Sway Bar (19mm solid or 25.5mm Competition Hollow)
Good choice? Good start? Wrong start? Haha, thanks guys!
Old Apr 13, 2012 | 02:57 PM
mbwicz's Avatar
mbwicz
Way has a large amount of respect on this forum, I would trust his reccomendation. I have the TSW springs and they ride better than the factory 'sport' springs that my car had. It didn't drop the front too much, but the rear dropped so that the car sits level. Rear sway bar is a good mod as well, don't forget the engine mount stiffener (NM or Powerflex), this will smooth out the shifting a bunch.
I put a double set of rear control arms on my car, and noticed that the rear felt more responsive. I don't think that this is wasted money. It took me about 4 hours to install the springs (I had trouble with one tie rod end), about 20 minutes to install the rear control arms. Swapping out the rear sway bar will take you about 30 minutes once the rear shocks are out. None of the work is difficult, you can 'borrow' a spring compressor from autozone for the job. Use an impact when pulling the tie rod end and removing the springs. Spring compressor is not required for installing the TSW's. Get an alignment right away.
Have fun.
Mike
Old Apr 15, 2012 | 06:32 AM
ARCooperS's Avatar
ARCooperS
Sounds good. Thank you!
S&CLC
Jul 24, 2017 07:12 AM
mishanja
Nov 5, 2014 02:13 PM
Bulldog_Blue
Jan 15, 2014 03:30 AM
Mini_Me_R53
Electrical
Jan 13, 2013 12:26 PM
