speedo reading 4mph faster how do i fix
Old Apr 8, 2012 | 12:15 PM
inkspot1967's Avatar
inkspot1967
i noticed on my 2008 MCs cabio that my speedo and on tach is reading 4mph faster then my TomTom gps also i use the Torque android app with elm327 bluetooth adapter hooked to esc and both show same speed but 4mph slower.
how do i fix this?
Old Apr 8, 2012 | 01:41 PM
DneprDave's Avatar
DneprDave
That's normal. There's a thread here, somewhere, talking about that. It has something to do with a law that prohibits a speedometer from reading lower than actual speed, but not higher.
You can get bigger tires to compensate.
Dave
Old Apr 8, 2012 | 01:49 PM
Blackbomber's Avatar
Blackbomber
Yep, first generation cars are the same. In fact, back when I used to read Car and Driver, they used to list speedometer error at 65mph for every test. It's THAT common of an issue.
Old Apr 8, 2012 | 01:54 PM
inkspot1967
wow that sucks so this means since its reading faster im actually adding more miles on the car then i really have on it.
Old Apr 8, 2012 | 02:29 PM
Ive's Mini's Avatar
Ive's Mini
No, if you look, the odometer reads correctly, only the speedometer is deliberately set 3-4 mph off from the factory. Mileage is not affected.
Old Apr 9, 2012 | 05:11 AM
yetti96's Avatar
yetti96
+1 The speedo is only adjusted in its display, not in the actual counting of miles.
Old Apr 9, 2012 | 10:38 AM
cristo's Avatar
cristo
Alliance Member
There is a simple fix to the speedo error problem.
Simply go 4 mph faster than you intend to go.
Problem fixed!
Old Apr 9, 2012 | 10:51 AM
Blackbomber
Problem fixed!
Yep, elegantly simple.
Old Apr 9, 2012 | 11:24 AM
rkw's Avatar
rkw
Oh really?
Someone opens a new thread about it every week! Seriously though, the speedometer can be adjusted in the computer with NCS Expert programming software: https://www.northamericanmotoring.co...ml#post3360825
Old Apr 9, 2012 | 12:34 PM
DneprDave's Avatar
DneprDave
Originally Posted by rkw
Oh really?
Yup.
https://www.northamericanmotoring.co...ter-v-gps.html
https://www.northamericanmotoring.co...can-gauge.html
https://www.northamericanmotoring.co...er-is-off.html
Dave
alistaircookie
Oct 8, 2015 10:52 AM
HaveATank
Sep 4, 2015 08:04 AM
jesterofatlas
Aug 31, 2015 07:58 AM
Aug 27, 2015 12:25 PM
Herleman
Aug 16, 2015 06:41 PM
