3 tire choices - please help
Old Apr 7, 2012 | 04:50 PM
mdutton11's Avatar
mdutton11
I have 3 tire dealers in the area and have narrowed down to 1 from each. Say bye bye to the runflats! I will not be driving the mini in the snow so highest performance with lowest noise is the best. If these are all bad - let me know so I can figure out other options. Any input would be greatly appreciated.
Les Schwab - Toyo Proxies all season BW $889
Costco - Bridgestone Potenza S04PP $723
Eagle Tire - Goodyear Eagle GT $707
THanks in advance
Old Apr 7, 2012 | 08:03 PM
Jim Michaels's Avatar
Jim Michaels
The Bridgestone is a Maximum Performance summer tire, and the other two are all-season tires, so the Bridgestone should easily have the highest grip and handling performance; at least in dry and mild conditions.
To make your decision somewhat more complex, but more likely to lead to a satisfactory outcome, you might go to www.tirerack.com to do your tire research, even if you buy elsewhere. You'll be able to compare any tires within (or across) any categories you choose, but at some point you'll still have to make compromises among performances such as dry grip/handling, all-season versatility, noise and ride comfort, tread wear, and price.
After deciding on a "best" tire for your applications, see if you can find that tire locally for a good price. If not, you can order a set from Tire Rack and have them installed locally.
Old Apr 8, 2012 | 05:30 PM
howsoonisnow1985's Avatar
howsoonisnow1985
Yeah Tire Rack has way better performing tires foe le$$.
Old Apr 8, 2012 | 05:38 PM
cp3657197's Avatar
cp3657197
none of those I will consider. got to tire rack and check out Michelin Super Sport, good review and top notch in its class...
just my $0.02 of the matter...
Old Apr 8, 2012 | 07:01 PM
K20K1LLA's Avatar
K20K1LLA
Dunlop Direzza Z1 Star Specs. Performance/dollar can't be beat. Tirerack.com has them for $133ea right now. Iv'e heard the Bridgestone Potenza RE11 is supposedly a little more grippy but those go for >$170ea. Way Motor Works recommended the Yokohama Advan Neova AD08 but again those were more expensive than the Star Specs.
Old Apr 8, 2012 | 07:06 PM
Bredto's Avatar
Bredto
Another vote for TireRack. They will always have best prices (even after shipping) and it's the only place I've found that actually does head to head tests with tires.
Old Apr 8, 2012 | 07:38 PM
gawannamini's Avatar
gawannamini
I'm running Michelin Pilot Sport A/S Plus and love them. Smooth, quiet, good grip wet and dry and even has 45k tread life warranty. This is an all season tire but they also make it in a summer tire. I up sized to a 215 in lieu of stock 205's. Agree that Tirerack is a great source. Check out owner survey results.
Old Apr 8, 2012 | 10:11 PM
Btwyx's Avatar
Btwyx
They're a bit of overkill for the street, and a bit noisy. The RE11 is faster on the track.
Old Apr 9, 2012 | 05:02 AM
dbrier's Avatar
dbrier
While the Star Specs and RE-11 will offer amazing grip, they aren't quiet at all. They are a race tire for the street.
The Contential DW offers great grip with OK noise levels.
Old Apr 9, 2012 | 01:15 PM
martinb's Avatar
martinb
The Direzza's were top rated by Car and Driver. Second place were the Hankook Ventus V12 Evo's that I run. (Direzza's weren't available in my size.) Of course, these are summer tires and I live in Northern California.
Old Apr 9, 2012 | 03:07 PM
davisflyer's Avatar
davisflyer
+1 on the Contis, nice compromise. I have run the RE-01R's before and they were fantastic (I'm sure the RE-11's are even better), but tires wore quickly.
Old Apr 9, 2012 | 03:38 PM
mdutton11's Avatar
mdutton11
Thanks for all the good info I checked with Les Schwab about installing tires from another dealer and they said close to $200 due to the "performance tires and sensors". Sounded pretty rediculous to me. Any ideas what I shoul dexpect to pay for mount / balance and install?
Old Apr 9, 2012 | 04:18 PM
F450HarleyMini's Avatar
F450HarleyMini
Tire balance (road force)& installation
About $18:50 to $25 per tire. Road forced balancing is a bit more than regular balancing but it's highly recommended. Also check tire rack website for balance/installation by zip code to get a better feel for your locality.
Old Apr 10, 2012 | 05:56 AM
Alex@tirerack's Avatar
Alex@tirerack
Any ideas what I should expect to pay for mount / balance and install?
With TireRack's recommended installers you can find very reasonable installation rates.
Old Apr 10, 2012 | 06:27 AM
mdutton11's Avatar
mdutton11
Good lead -their local installer is $20 per tire + roughly $60 shipping to WA. I would save a few $$$ overall and probably get a higher performance tire but the convenience and local warranty service is attractive. I will not be driving on a track - just some mid life crisis cruising and curving so I don't need the best of the best. Ahh choices
Old Apr 10, 2012 | 06:50 AM
timtim's Avatar
timtim
You mentioned Costco, you can get the Michlen Pilot Sport A/S+ at Costco. I think it's the best all season tire available for your car. They run a $70 off 4 coupon so total cost would be like $700/set of 4.
If you are concerned about total cost, they charge like $15 to M&B. I think they charge an additional $10 per tire for the sensor kits if needed.
Good Luck
Old Apr 10, 2012 | 07:15 AM
MYT MSE's Avatar
MYT MSE
Just bought the Michelin Pilot Sport AS Plus last week. Got a great deal on them, $500.17 installed, tax included. Was a local shop here. Anyway, I am very pleased with this tire. Great grip, very little noise, and they look bada$$. I would highly recommend them.
Waszak
Oct 21, 2017 05:55 PM
Norton70
Sep 7, 2015 05:06 PM
Sep 3, 2015 01:45 PM
Ntety
Sep 2, 2015 08:39 PM
