Suspension PSS10 Linear Spring Conversion ?
Old Apr 7, 2012 | 01:50 AM
MattyKHZ's Avatar
MattyKHZ
As my front left camber plate bearing is shot I am looking at new camber plate options.
Would I be correct in thinking that if I used a Vorshlag or other camber plate that works with coilover springs ie 60mm diameter linear rather than my current progressive would this then allow me to go linear up front with something like Swift or Hyperco springs.
It seems many of the manufacturers do plate designs dependent on the shock they are being used with. I am sure SPC/Eibach which I currently have do not so that must mean original spring perch is used rather than a new one from the camber plate manufacturer?
Just thought if I need to get new plates it might be an option to sort out springs at front also. Any idea of good spring rates? Sure they are 6 inch springs......
NYMADMINI
Dec 14, 2016 02:33 PM
Sep 29, 2015 12:11 PM
Emnotek
Sep 29, 2015 07:37 AM
gnhovis
Sep 28, 2015 10:56 AM
gnhovis
Sep 28, 2015 04:07 AM
