Suspension Anyone have TSW Spring pictures and information
Old Mar 27, 2012 | 08:02 PM
blue2turbo's Avatar
blue2turbo
Ok, so I have Swift springs, but I am considering getting rid of them and getting TSW's. I originally was going to get TSW's, but I wanted springs and at the time, there was the issue with the V3's raising the front end and still lowering the rear. Saw some pictures, and I personally definitely couldn't ride around like that.
I LOVE the way the Swift springs look with the drop being even all around, but they are/can be pretty stiff for the area I live in since the roads are terrible all over.
I've searched over and over and can only find a few pictures scattered about, so i was wondering if anyone has TSW Springs installed that doesn't have the issue with the front raised and if they could post up some pictures. I am on 17" wheels with stock size tires, so if you have 17's even better.
I'm getting ready to install Powerflex LCA bushings, Powerflex rear trailing arm bushings, Koni Yellow's, and a HSport Comp rear sway bar, and I'm just trying to decide if I should keep the Swift Springs or swap to TSW IF the problem has been fixed.
Thanks in advance!
Old Mar 27, 2012 | 08:11 PM
vkash1208's Avatar
vkash1208
I am on 17" web-spoke on 215/45 17, so just a little bit of a taller tire then stock. Give me a couple weeks and I will get you a picture of the newest TSW springs.
Old Mar 27, 2012 | 08:19 PM
blue2turbo's Avatar
blue2turbo
215/45/17 is the tire size I plan on getting when my current 205/45's are dead. Did you just buy a new set of TSW? Did you talk to Way to find out if he resolved the raised front issue? I may call him to ask while I decide.
I really just need to figure out if Swift is the right spring to keep. I want something slightly more comfortable, but I'm not going to FSD's or stock ride height. I have a set of brand new HSport Springs too, but I read a lot about them sagging and I really don't want to deal with that.
I also don't want my car any higher then it is now, which is roughly 3/4" drop. So Tein H-Techs are out.
Old Mar 27, 2012 | 08:26 PM
vkash1208's Avatar
vkash1208
you should go with a 215/40 17. but yeah, call Way
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
W0TM8
Dec 19, 2019 07:50 AM
aldito2
Nov 25, 2015 09:33 PM
Manny_cooper
Nov 4, 2015 09:42 AM
Emnotek
Aug 13, 2015 05:47 PM
