Interior/Exterior Air/fuel mixture guage...anyone install one?
Old Mar 3, 2004 | 02:13 PM
MSFITOY's Avatar
MSFITOY
If so, I'd be interested in how you did it and where the wiring goes. Thanks.
Old Dec 1, 2007 | 11:24 AM
AstroBlackS's Avatar
AstroBlackS
Ressurecting this thread. I'm planning on getting an Air/Fuel guage, and would like to know about hooking it up. The wiring and what not I shouls be able to handle, but I'm not sure about what comes with the guage. Does it come with a sensor of some sort or is that something that must be bought seperately? Also, where does that sensor get placed in order to read the Air/Fuel ratio?
Old Dec 1, 2007 | 03:52 PM
joshK's Avatar
joshK
The gauges are nothing more than a light show unless you buy a Wideband gauge. These gauges will use an O2 sensor similar to the ones your car's emissions system uses. Usually you add a bung to your exhaust piping and screw it in. Some aftermarket exhausts already have a bung for this purpose.
Old Dec 1, 2007 | 04:34 PM
kapps's Avatar
kapps
Most aftermarket A/F gauge kits will be wideband. A narrowband would be useless to you anyway. They will either come with a sensor or say which one to get. As joshK said, you will most likely have to weld a bung onto your header for the sensor.
Old Dec 4, 2007 | 01:25 PM
AstroBlackS
Cool. Thanks for the feedback!
Old Dec 26, 2007 | 11:38 AM
Bahamabart's Avatar
Bahamabart
For Xmas, I gave my son a PLX DM-5 combo. What attracted me was the fact that I would not have to add a bung but replace the existing sensor and "share it" w/ the gauge and the ECU. The instructions are a little light explanation wise - at least for me (i.e. not the sharpest tool in the shed). It may make more sense to just add a bung and wire up as standalone.
I need help identifying the following wires on the ECU Harness -
1) 12V power
2) chassis GND
3) 02 heater power
4) 02 heater GND
5) 02 signal Input
Appreciate any help you can offer.
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
