Suspension How much does choking up on an adjustable rear sway bar change the stiffness?
Old Mar 21, 2012 | 02:38 PM
JPMM's Avatar
JPMM
The end bends are about 6" long so moving the mounts about 2" forward would stiffen a bar about 2/6ths or about 33%?
Old Mar 25, 2012 | 04:50 AM
claud's Avatar
claud
If you check with the manufacturer of the bar you like, they can tell you the percentage stiffer than stock for each setting.
Old Mar 25, 2012 | 05:48 AM
drsimmons's Avatar
drsimmons
Claud is correct, the manufacturer should list the percentages of change.
Don't know what brand you have but I've got an h-sport 19mm set in the middle setting and it's perfect for my type of driving (daily use and a little spirited road running, no track). Really takes the understeer out.
Old Mar 25, 2012 | 09:32 AM
cristo's Avatar
cristo
Alliance Member
It's a little bit more complicated than that, but still pretty simple.
Here's the standard formula:
http://www.klaindustries.net/technical/drplink.htm
Plugging in 3/4" (19mm) for Diameter and 35" for the mid-Bar length (a wild guess - please
measure yours and re-do the calculations for better accuracy) gives 270 lb/in for 6"
perpendicular ends (A = C), and 626 lb/in for 4" ends (a 132% increase)!
minipopkart
Aug 13, 2015 05:22 AM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
