Drivetrain Forge Valves
Old Mar 20, 2012 | 09:15 PM
akng's Avatar
akng
Forge Valves
Anyone knows the difference between the following 2 Forge Valves?
1) FM207V - Mini Cooper S and Peugeot Turbo uprated valve - (Listed for $250)
http://www.forgemotorsport.com/conte...product=FM207V
2) FMDVR56A - Blow Off Valve Kit for Mini Cooper S R56 models - (Listed for $280)
http://www.forgemotorsport.com/conte...oduct=FMDVR56A
They both look the same to me. Could (1) be the diverter valve and the (2) being a new valve that combines the diverter valve mechanism along with their Blow Off adaptor?
I am looking to get the diverter valve and the replies from the Forge customer service seems confusing to me. So if someone has knowledge about this issue, I would really appreciate their help. Thank you so much in advanced.
Old Mar 23, 2012 | 06:18 AM
Sacred Disorder's Avatar
Sacred Disorder
The bottom one is an actual BOV, you can see the holes drilled into the bottom. The Forge diverter valve is solid all around the bottom. A BOV will more than likely cause your car to throw a CEL and run rich when the BOV Vents.
Old Mar 23, 2012 | 10:16 PM
akng's Avatar
akng
Actually, I have cleared it up with Forge as well and they have confirmed that while the FM207V is the Diverter Valve, the other one is indeed a Vent to Atmosphere Blow Off Valve which works like the Diverter Valve. I guess this is a new product from them then since I haven't seen it before!
olson187
Oct 21, 2015 05:25 AM
Fordgt4
Oct 10, 2015 10:42 AM
Southern Marylander
Oct 1, 2015 07:53 AM
micromini234
Sep 30, 2015 07:36 PM
Emnotek
Sep 29, 2015 07:37 AM
