Pre-Order Special - Brown Line Professional Grade Digital Torque Wrench
Old Mar 15, 2012 | 12:32 PM
phil@detailersdomain's Avatar
Product Specifications
Patented Technology
Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
*Patent No.: US 7,367,250. Additional patents pending
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
http://www.youtube.com/watch?v=mLeHXVGIimo&list=UUC0yUZXAbtH1BIj2ZU1z9aQ&feature=plcp&context=C4a32065FDvjVQa1PpcFNcvaufZFD1D0M41Kt_xvGZuhRw8_JkS_w=
List Price: $150 ---> Pre Order Special $115 including case and shipping.
Click here to get in on the Brown Line MetalWorks Pre Order Deal
W0TM8
Dec 19, 2019 07:50 AM
shark715
Aug 30, 2015 07:01 PM
tag1260
Aug 24, 2015 05:52 PM
minipopkart
Aug 13, 2015 05:22 AM
minipopkart
Aug 9, 2015 12:13 PM
