Correct brake fluid level?
Old Mar 15, 2012 | 10:58 AM
matthew-w's Avatar
matthew-w
Hi,
I just had my brake fluid flushed at the dealer, and was told I have a slight leak in the [power steering] system. For that reason I checked the level today so I had a point of reference so I would know when to top if off (before having the repair done).
The manual doesn't explicitly state what the correct brake fluid level is. My cap has a "dipstick" of sorts with two discreet lines. The fluid is reading at halfway up lowest line.
Where's the sweet spot?
Thanks!
Old Mar 15, 2012 | 12:29 PM
Fly'n Brick's Avatar
Fly'n Brick
Wrong question, bub (owner's manual has a solid hint). The right one is: Why did the dealer send a car out of his shop with a leaking system of any sort? I'd start to question his reliability.
Old Mar 15, 2012 | 12:43 PM
matthew-w's Avatar
matthew-w
'Brick,
My mistake: My original post should have read, brake fluid flushed at the dealer, and was told I have a slight leak in the power steering system.
I'm getting a few drips a week.
Old Mar 15, 2012 | 12:44 PM
Eric_Rowland's Avatar
Eric_Rowland
The brake system is one place you don't want a leak. They system needs to be air tight, otherwise the fluid will be absorbing water, be less effective, and compromise the brake hardware.
Old Mar 15, 2012 | 01:04 PM
cristo's Avatar
cristo
Alliance Member
Mine has "min" and "max" lines on the outside of the resevoir.
Old Mar 15, 2012 | 02:01 PM
Fly'n Brick
Even so, If the dealer noticed a leak, he should have solved the problem. You can arm-wrestle a MINI without the steering pump but why have to put up with the hassle.
"OK, new pads and rotors all ready for you. By the way, there's a nail in your off side rear tire. Good luck with that."
Old Mar 15, 2012 | 06:30 PM
NC TRACKRAT's Avatar
NC TRACKRAT
Veteran: Navy
Either I'm confused or you are. I think you have the pwr strg reservoir confused with the brake fluid reservoir. The pwr strg system has a dipstick in the cap. The brake fluid res. has max/min marks. Suggest you read your owners manual closely for answers and get back to us once all is clear.
HaveATank
Sep 4, 2015 08:04 AM
HaveATank
Aug 24, 2015 10:26 AM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
