Suspension Front right shock moves back and forth. Something broke?
Old Mar 13, 2012 | 12:48 PM
paintdude258's Avatar
paintdude258
I recently got new shoes installed on my 2005 mini cooper S, and the mechanic showed me something that he found very odd. The front right shock will move back and forth about 1-2 inches with a little force. The front left does not do this. Ive driven the car for over a year and not noticed any odd feedback that such a thing could cause. Any ideas on what could cause the shock to be able to move back and forth as described, and does such a thing effect the mini cooper in any way??
Old Mar 13, 2012 | 01:29 PM
HRM's Avatar
HRM
I would find a new mechanic. Mini front struts are just like any other ones. If something is wrong, it should be pretty obvious to a mechanic.
Old Mar 13, 2012 | 01:36 PM
Eric_Rowland's Avatar
Eric_Rowland
An inch or two is huge. My first question would be 'fore - aft' or side to side. Either way, it should be mounted solidly.
Old Mar 13, 2012 | 01:52 PM
paintdude258
Front to back
Old Mar 13, 2012 | 02:22 PM
quikmni's Avatar
quikmni
Open the hood and look at the top of the strut/shock where it mounts in the engine compartment. The shaft of the shock comes up through a rubber bushing. Look at the bushing, might need a flashlight to see well, to see if it is cracked or torn. If badly torn it will allow the shock to move around.
Old Mar 13, 2012 | 03:54 PM
Da_Ghost's Avatar
Da_Ghost
Originally Posted by paintdude258
Front to back
Is it moving from the upper part or bottom? A worn control arm bushing will allow the wheel/suspension assembly to move like you describe. If it's moving from the upper part, I would say it's the strut mount.
Old Mar 13, 2012 | 07:11 PM
paintdude258
Thanks for all the input guys. Its dark, so im gonna go look more at it tomorrow!
Old Mar 13, 2012 | 07:48 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
That really sounds like worn out control arm bushings, good chance to upgrade to the powerflex.
Old Mar 13, 2012 | 08:18 PM
Applesauce's Avatar
Applesauce
Definitely time for a new mechanic. I would also guess control arm bushings, possibly tie-rods. In any case, your mechanic should be smarter than this...
surfblue
Oct 24, 2018 01:20 AM
Zettinger
Aug 25, 2015 04:04 PM
Emnotek
Aug 13, 2015 05:47 PM
Minibeagle
Aug 13, 2015 10:00 AM
minipopkart
Aug 13, 2015 05:22 AM
