Drivetrain nm intake installed
nm intake installed
installed my 2nd mod today , the nm instake, the sound is amazing! the fit and finish is awesome, also the instructions they provide make it easy for anyone to install. at first it seemed like ive lost top end power
but i kept driving it, i think its better now. im sure i need a tune to get the most out off it and that is still on its way after i install the down pipe. anyone else thought they might have lost top end power after this isntall?
drove it again today but in the warmer weather and it performed alot better, maybe the ecu is getting used to it idk but its deff performing better, i also cleaned my maf. what do you mean by heatsoak?
Never had a problem with my NM CAI after install. Be careful when cleaning and reoiling the filter. Don't want to overdue the oil, it can
impact your MAF.
I assume the one question on 'heat soak' is referring to the hot engine air
entering the CAI filter and causing the engine to feel sluggish. I haven't had that issue either.
I am installing a step intercooler to help in heat. It should help in the hot
summer months to come.
impact your MAF.
thanks for the explanation, my intake temps are about 5 to 10 degrees hotter than the exterior air, i have the torque app that i monitor all the temps with, the car is acting much better now.
squawSkiBum
Oct 2, 2015 09:21 AM
Aug 21, 2015 11:25 AM
the more fresh air for the engine the better
