Help Please - MCS Mystery Oil leak/usage
Old Feb 20, 2012 | 12:20 PM
MINI Marvin's Avatar
MINI Marvin
A month ago I was driving the car and it sounded like a lawn mower (e.g. rattling engine). I checked the oil and it looked fine (I have always hated the oil dip stick - insanely hard to read IMO). Concerned I brought it into the dealer to check it out. Turns out it was down 3 quarts of oil!
They couldn't see an obvious sources of leaks so they did an oil change and it purred like a kitten again. We decided to wait and see. 1 month and 1K miles later I had to add a quart of oil to it. The rattle sounding engine has started to return (not as loud) so I brought it in and they still cant find a problem (no obvious leaks). They did a compression test and it is fine. They said they could open the engine and continue to look but were concerned about what they might find/what it could lead to. To save me some money on the whole thing (they are $135/hour) they suggested I take it to a local MINI shop they know to do the work that has a more reasonable per hour rate.
I only planned on keeping the car to 100K miles so maybe another year or so, so not sure if its worth sinking lots of money into it. I plan on taking it to the MINI shop this week, but wondered if people have had this issue with other MCS's... I wonder if I killed it driving it oil starved. I love the car (its more like a member of the family than a car) and it has been great so I am really not pleased. Any help would be great.
Old Feb 21, 2012 | 10:24 AM
Eric_Rowland's Avatar
Eric_Rowland
If there's no oil on the ground, there's no leak. Some cars burn oil. Check it every 500 miles (~ every other fillup) and fill as needed.
Old Feb 21, 2012 | 01:33 PM
ZippyNH's Avatar
ZippyNH
What year mini?!
Some do burnoil....others have leaks that result it itgetting blown back, and no real drips...looking under the car can give you a clue if it is oily, or just burning it.
Sounds like you need to learn how to read a dipstick better...pull it out, wipe it off, stick itin, wait a few seconds, pull it out, and read it....
could have been, still might have been a very $$ mistake....
Old Feb 21, 2012 | 06:48 PM
kris kross's Avatar
kris kross
Don't ignore the signs! Mine ran dry 4,000 miles after an oil change and the knocking was a spun rod bearing. The knocking got worse even with the correct oil level. I had to replace the engine. Keep a close eye on the oil level. If your low oil pressure light comes on or hear knocking, turn off the car immediately!
Kimolaoha
Jul 5, 2023 01:04 PM
cerenkov
Apr 24, 2018 07:47 AM
maniacalmorgan
38
Sep 29, 2015 04:56 AM
ShadyCoop
Aug 24, 2015 06:05 AM
clintmeister
Aug 12, 2015 11:11 AM
