R60 Strong Sulfur Exhaust
Old Feb 15, 2012 | 02:46 PM
jaffo's Avatar
jaffo
My Mini Countryman S has less than a 1000 miles. I’ve noticed on a few occasions (especially when taping the accelerator a little more than usual) that the exhaust stinks of sulfur. The tailpipe (once cleaned) also seems to develop black soot faster than I think a new car should, but I realize this may be a topic of debate.
Except for weekends, most of my driving is short local trips. Some threads suggest trying other brands of gas (re: sulfur content). So far I’ve used Hess and Sunoco premium with no noticeable difference in exhaust smell. I'll try BP next.
Anyone have same issue or a dealer remedy ?
Cheers,
Old Feb 15, 2012 | 06:00 PM
ChubbyMini's Avatar
ChubbyMini
Cheers,
Hi Jaffo - I found this online.
When high sulfur fuel is burned, there is a chemical reaction in the catalytic converter causing the sulfur to oxidize. As the vehicle is driven, the oxidizing reaction odor in the converter will decrease with mileage and age.
1 Switch to a different brand of fuel and drive the vehicle for at least 100 miles. Monitor the decrease or increase in sulfur smell.
2 Do not add any type of 'fuel additive' as this could add sulfur to the fuel and cause/increase the odor.
3 Try to avoid extended periods of short trip driving or aggressive acceleration.
4 Request information from your local fuel dealers on the amounts of sulfur in their gasoline. Try to use fuel containing the lowest amounts of sulfur.
I hope it goes away
Old Feb 15, 2012 | 06:30 PM
drsimmons's Avatar
drsimmons
The cooper s tail pipes soot up easy. I believe this is called normal.
There was a thread on it but I can't seem to find it at the moment.
Old Feb 16, 2012 | 05:00 AM
jaffo's Avatar
jaffo
Thanks all,
I can't avoid the short trips (work is too close to home) but will give the Sunoco gas a little more time (only 65 miles since fill up). I also like knowing that the oxidizing reaction of the catalytic converter should decrease somewhat with age.
Jaffo
patsum
26
May 29, 2021 06:29 PM
shorenetworks
Nov 4, 2019 06:18 PM
embiggenedmini
Oct 15, 2015 12:36 PM
buckeye_hunter
Sep 2, 2015 01:24 PM
Sep 2, 2015 09:05 AM
