Suspension Where to find >70mm M14x1.5 wheel studs
Old Feb 14, 2012 | 08:01 PM
Erhan's Avatar
Erhan
Most vendors *I think* sell 65mm wheel studs. RMW sells 90mm which is excessive. I need something around 70, 75mm. Anyone know where can I find?
Thanks!
Old Feb 14, 2012 | 08:23 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
What size spacers are you trying to use?
Old Feb 14, 2012 | 08:26 PM
Erhan's Avatar
Erhan
12mm spacers. I actually currently have the M14x1.25 to M14x1.5 conversion kit that I bought from you. This one is 65mm, and it is not long enough (the bolts are about flush with the studs, makes me nervous). I need at least 70mm.
Old Feb 14, 2012 | 08:34 PM
Erhan's Avatar
Erhan
Here, I'm attaching pictures. The wheels are Konig Feather 17"x7 et40 and tires are 215/45 Dunlop Star Spec Direzza. I have BC Racing coilovers which do require 5mm spacers even with stock 16" wheels 195tires. The whole problem is the fronts, rears are fine.
By erhanh at 2012-02-14
Old Feb 14, 2012 | 09:18 PM
bluefox280's Avatar
bluefox280
The photos you show above depict that your studs are satisfactory.
Your lugs fully engage after three full rotations, any excess is unnecessary when it comes to threaded bolt design.
- Erik
sevin
May 2, 2026 06:11 AM
SosoMINI
Nov 22, 2015 03:17 PM
MINI VINI
Oct 13, 2015 08:57 AM
O4mcs
Aug 6, 2015 05:42 AM
