R50/53 Lower control arm help!!!
Old Feb 7, 2012 | 03:32 PM
Minicoopr50's Avatar
Minicoopr50
So I recently installed the springs on my 06 r50,
How the heck do you reach the lca bolt? The gas tank is in the way!
Old Feb 8, 2012 | 02:55 AM
HRM's Avatar
HRM
IIRC, just put the socket on first, then the ratchet on the socket. If it won't fit, you need different socket set (as in you have only deep ones)
Old Feb 8, 2012 | 06:48 AM
Evasive's Avatar
Evasive
What HRM said. You will want to insert your socket in the big hole on the subframe first. Once it's sitting on the bolt, connect your ratchet to the socket. If it still won't fit, you may need to hit up your local sears tools department. The socket will need to be long enough so that it doesn't sink too much in the subframe that your ratchet can't connect to it and if you have a bulky ratchet, you may want to look for one with a flatter head.
BRracing
Dec 22, 2015 09:25 AM
Manny_cooper
Nov 4, 2015 09:42 AM
yukinoinu
15
Aug 24, 2015 09:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
OutMotoring
Aug 6, 2015 09:32 AM
