Please help. Engine tick.
Old Jan 23, 2012 | 07:22 PM
Hankfrum's Avatar
Hankfrum
Ive posted awhile back about my car having developed a tick. Replaced the tensioner and the sound has come back. Understanding not all things are perfect that it may be my tensioner again. But the sound has been different this time. It still seems to be coming from the same side. But, the car is completely quite at start-up. it only develops the tick after the car has warmed up. Any ideas would be appreciated. Have looked at the basic stuff. thanx
Old Jan 23, 2012 | 07:26 PM
teamrubixcube's Avatar
teamrubixcube
You have the Tritec engine? (I do realize you posted in 1st gen...just making sure you meant to) You can hear the direct injection of the prince motors all day long.
Old Jan 23, 2012 | 08:32 PM
Eggburp's Avatar
Eggburp
I get a tick from my fuel tank vent valve. It seems to develop if the car is stored for any length of time. It is located just in front of the tensioner assembly. I can get it to go with a push on the throttle but it will return at tick-over.
Stick your trusty screwdriver to yur ear and check her out.
Old Jan 23, 2012 | 11:40 PM
Gamm's Avatar
Gamm
Several others, including myself, have had this problem. It's quite a common issue.
In my situation the sound also developed after about a minute after starting my engine.
If you're not sure about the sound, go have a look on youtube. There are several videos that will give you an idea if this is indeed the problem you're facing.
If so, here's what needs to be done;
Have your timing chain tensioner replaced. It's worth the try as it's not expensive at all.
Mini part numbers 11317510801 (6) & 07137510732 (7)
There's an easy way to access it by removing your passenger side wheel. Have a look on the forum as it has been explained several times before.
!TIP Wear gloves!
Old Jan 24, 2012 | 09:25 AM
proximo's Avatar
proximo
There were service bulletins posted on here somewhere that I'll have to track down when ours developed a tick. Can't remember what the issue was, but it was a "non-issue." Pull the vacuum line. If it goes away without the vacuum line attached, it's not a problem (like our -- according to the service bulletin).
Old Jan 24, 2012 | 09:59 AM
proximo's Avatar
proximo
Found it. Look at the following bulletin:
SIM 11 02 07
It mentions in the procedure SIM 11 02 08 which is related to the vacuum pump and normal operation. I haven't found the actual text for this item yet.
Old Jan 24, 2012 | 11:43 PM
Gamm's Avatar
Gamm
SIM 11 02 07
This is a service bulletin for second generation Mini, which has a totally different engine from the first generation mini's.
However, this was posted in the first generation section.
ROCNDAV
Oct 20, 2015 01:08 PM
jostevens
Aug 23, 2015 05:23 PM
slipmagt
Aug 22, 2015 02:14 PM
Sikness
R57 :: Cabrio Talk (2009+)
Aug 20, 2015 06:00 PM
