Question about offset
Jan 20, 2012 | 04:13 PM
When looking at offset on a wheel, does a higher number mean it's closer to the inside or the outside of the car? Does adding a spacer increase or decrease the offset?
Jan 20, 2012 | 05:16 PM
higher means closer to the inside. spacers lower offset
Jan 20, 2012 | 05:25 PM
Jan 21, 2012 | 08:48 AM
OK, so if I'm looking at getting a wheel with a 40mm offset, if I get a 5mm spacer, it will push the wheel out further, correct?
Jan 21, 2012 | 11:09 AM
Quote:
Originally Posted by
davisflyer
Correct, as the overall offset would be (40mm - 5mm = ) 35mm.
- Erik
Jan 21, 2012 | 11:12 AM
Creeve & Bluefox280
What they said...
Reason: Spelling
Jan 21, 2012 | 12:15 PM
bluefox280
- Erik
OK, with that part settled, how little offset can i get away with on stock 17" tires without rubbing?
Jan 21, 2012 | 05:43 PM
davisflyer
Well remember, offset is in relation to the wheel
width , and not the diameter.
What's the width of the wheels you want to run with the 40mm offset?
- Erik
Jan 21, 2012 | 06:13 PM
Offset also affects torque steer. The less offset that you have the more torque steer. This is why fwd cars have so much offset. It also affects how much load you put on the bearings; the less offset (the more the wheel is outboard from the center of the car) the more highly loaded the bearings are and the faster they will wear out.
Jan 21, 2012 | 08:07 PM
Good questions!
I'm looking at a couple different wheels, 17x7 with 38mm and 40mm offsets respectively.
Jan 21, 2012 | 08:27 PM
davisflyer
That's only 8-10mm difference than the OEM 7" wide wheels @ 48mm offset; you'll have zero problems.
- Erik
Jan 21, 2012 | 10:09 PM
bluefox280
- Erik
schwac2
Jun 14, 2016 04:06 PM
actualsize37
Nov 18, 2015 08:58 AM
donniedarko
Oct 21, 2015 01:15 PM
