Minor Coolant Leak 04 MC Help!
Old Jan 17, 2012 | 02:39 PM
UKNUT's Avatar
UKNUT
I have a very minor coolant leak somewhere around the radiator area, but I cannot find it! If it sits all night there will be a small puddle under the very front of the car. I've looked all over and can't see any weeping or residue. Any ideas??? Thanks!
Old Jan 17, 2012 | 03:46 PM
quikmni's Avatar
quikmni
When my 06 MCS leaked overnight it was leaking at the thermostat housing/gasket.
Old Jan 18, 2012 | 05:28 AM
UKNUT's Avatar
UKNUT
Thanks, I'll check that out.
Old Jan 21, 2012 | 08:53 PM
Hobibill's Avatar
Hobibill
What did u find? My 04 MCS is doing the same thing.
Old Jan 22, 2012 | 02:05 PM
kapps's Avatar
kapps
My MCS was leaking way up front too and it turned out to be the radiator. Eventually, I noticed a discoloration right in the middle where the coolant was evaporating and leaving a whitish residue. I ended up having to replace the radiator.
Old Jan 23, 2012 | 12:34 PM
Bradg33's Avatar
Bradg33
I just dealt with a fairly major coolant leak in my 05 R53. Turned out it was the water pump. Had nasty coolant all over the front of the block and down onto the oil pan.
Old Jan 23, 2012 | 12:41 PM
JACKDHRIPPER's Avatar
JACKDHRIPPER
Mine was a pinhole in the radiator! Just need a system pressure test..
Old Jan 23, 2012 | 12:55 PM
dannyhavok's Avatar
dannyhavok
Thermostat housing is an extremely common failure on the first gen, odds are good that's your problem. It happened to me, same symptoms. It was fixed under warranty in my case but I don't think it's a pricey issue, even at the dealer.
Old Jan 23, 2012 | 01:04 PM
mrblazn's Avatar
mrblazn
I say either water pump or radiator.
Old Jan 23, 2012 | 02:02 PM
redhotchilipepper's Avatar
redhotchilipepper
Had same issue a while back but couldnt seem to find the source. It turned out to be the radiator. Try taking the plastic splash shield off from underneath the car directly behind the bumper. When I took mine off it was covered in white residue. The dealer told me most coolant leaks go undetected because this oem splash shield catches most of the leak and residue when the radiator fails. Also check the insulating foam on the bottom passenger side of the radiator. When the radiators fail they tend to become hard and have discoloration. Good luck!!
Old Jan 26, 2012 | 07:21 PM
mjhanna's Avatar
mjhanna
Cheap fix...maybe
FYI.... Just saw that minicarparts.net has K-seal on sale for $12. If it's the radiator, might be worth a try for $12 bucks!!!
shorenetworks
Nov 4, 2019 06:18 PM
debitsandcredits
Sep 21, 2015 08:34 AM
OdzBodkinz
Sep 11, 2015 07:20 PM
mimaal
Sep 4, 2015 09:09 AM
