R50/53 Crank Pulley Yes or No?
Old Jan 12, 2012 | 11:12 AM
niquemarshall's Avatar
niquemarshall
Im going to be changing my belt when i get around to it and im thinking of a 2% crank pulley, but i hear of it causing alot of problems, at the same time some people are saying its fine. Im not sure whether to just use the crank pulley and hope it doesnt vibrate, or just use the 05-06 crank pulley.. I need a verdict
Old Jan 12, 2012 | 11:28 AM
Luice73's Avatar
Luice73
I have a 15% reduction supercharger pulley and a 4% crank pulley. No problems to report. I was told adding the light crank pulley was equal to removing 100ilbs from your car.
Old Jan 12, 2012 | 11:29 AM
Luice73's Avatar
Luice73
You will want to use the JWC belt too. Not just the S belt
Old Jan 12, 2012 | 12:06 PM
niquemarshall
I heard it was 63 specifically, but does the engine vibrate more? I heard form sources that it wears your bearings out since its essentially like removing the harmonic balancer
Old Jan 12, 2012 | 12:14 PM
apexer's Avatar
apexer
I have a 15% S/C pulley and a 2% Crank Pulley. NO PROBLEMS
Old Jan 12, 2012 | 12:16 PM
kazlot's Avatar
kazlot
Way Motor Works sells the ATI Super Crank Pulley, a 2% reduction, if you're considering this mod.
http://www.waymotorworks.com/super-d...ulley-r53.html
Hope this helps...
Old Jan 12, 2012 | 12:33 PM
quikmni's Avatar
quikmni
To keep a harmonic balancer but with the benifit of removing the failure prone OEM pulley plus spin my JCW supercharger a little faster, I purchased the ATI 2% pulley. I have not installed the new pulley yet. The disadvantage is it does not reduce any weight.
Old Jan 12, 2012 | 06:23 PM
nodoze's Avatar
nodoze
People have been using non-dampened pulleys for a while with no problems. There are too many variables to just make a blanket statement saying "the pulley definitely caused this"
Old Jan 12, 2012 | 08:56 PM
niquemarshall
Ok I was just wondering how safe this mod was... I was reading on MA and MT and I was hearing a lot of problems with vibration and bearing issues and all said cars ha this lighter crank pulley installed
Old Jan 14, 2012 | 07:49 AM
NH_MCS's Avatar
NH_MCS
I've had a Craven crank pulley on for 20K miles, no problems. From what I hear, the problem with the lightweight non-dampened crank pulley is when running past stock redline, AFAIK >7200RPM.
Old Jan 14, 2012 | 08:57 AM
JCWSLAYER's Avatar
JCWSLAYER
Harmonic dampers serve a purpose, if you dont use one you are reducing the life of your motor period. Better explanation ? check the link
http://www.atiracing.com/products/da...mper_dinan.htm
Old Jan 14, 2012 | 09:43 AM
niquemarshall
Yea i think imma just go the safe route and use a damper
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
Debi's Coop S
Oct 3, 2015 08:19 AM
VanisleRyan
Sep 30, 2015 08:35 PM
daviday
Sep 25, 2015 01:31 AM
