R50/53 2005 R50 Misfiring...not sure why.
Old Jan 10, 2012 | 07:30 PM
Cooper1's Avatar
Cooper1
My '05 mc is misfiring after startup the other day, and i just replaced all plugs, wires and coil about 4 months ago. any ideas? taking it to a shop to get a more accurate diagnosis, hopefully. codes right now are p03 (reader won't give last two digits) p2097, and p1477 which comes and goes.
Old Jan 10, 2012 | 08:00 PM
MiniMoto768's Avatar
MiniMoto768
What kind of plugs and coil? MSD? I have heard of issues with misfires with them. If you have the old stuff i try to switch to your older coil and check to see what happens, then try the wires. Goodluck and hope that helps alittle.
Old Jan 12, 2012 | 07:42 AM
Cooper1's Avatar
Cooper1
The coil I put in there is a Beck/Arnley ignition coil, and the plugs are NGK (not sure of the model #, but they are for MINI)..wires are made by Denso. Brought it to the shop this morning, I just hope its something simple, I go to college and don't have the time or resources I would back home to work on it and look for any one of the many sensors, wires etc.
Old Jan 13, 2012 | 12:05 PM
Cooper1's Avatar
Cooper1
It turns out it was the ignition coil afterall...i never would have thought it would have failed after only 4 months, but it sure did...cylinder 3 wasn't firing at all. problem solved.
vargasgal
Sep 17, 2015 10:02 AM
Sep 10, 2015 01:50 PM
Sep 10, 2015 01:48 PM
Sep 10, 2015 10:52 AM
