Suspension NOOB Coilover question
Old Jan 4, 2012 | 12:35 PM
MINIng's Avatar
MINIng
Finally mustered up the ***** and time to do this diy, but I got no idea on how high i should tighten the perches. I'm right about to put the coilover in the hole thingy and I'm looking to decrease wheel gap and just get low. I've used the search button, but i think my question is just too noobie for it to be brought up.
I'm not looking for height suggestions, just wondering if the perches should at least touch the spring before i continue on. I've screwed the top hat on already, but if i'm doing it wrong, let me know
Any advice/admonishing/replies are welcome...
Old Jan 4, 2012 | 12:48 PM
Bigprfed22's Avatar
Bigprfed22
Have them all equal, measure, if you count threads you may be off by a mm or 2. if the spring isnt touching the perches then it might be slammed when you put the car on the ground. Good coil overs come with an initial static worksheet, i think you can find em offline too. That dont have to touch the perches but like i sai it might be uber low when you put it on the ground.
Old Jan 4, 2012 | 01:06 PM
MINIng's Avatar
MINIng
Thanks for the heads up,
Was originally going to count threads, but i think i will measure.
BTW, what exactly do i measure
(ugh, i hate typing with greasy hands)
Old Jan 4, 2012 | 01:15 PM
Bigprfed22's Avatar
Bigprfed22
The technical measuring point should be from the perch to the center bore of the control arm mounting point. you can get a good reading by using a pin or the bolt itself to creat a point of reference. Then once all of them are at equal measurements then your adjustments can be made by placing a pieace of tape on the same location of the coilover unit and measuring to there. Always make your adjustments with no load on the coil.
Old Jan 4, 2012 | 03:01 PM
MINIng's Avatar
MINIng
You are the man, Sir
I'll post a pic of the accomplishment tomorrow
Old Jan 4, 2012 | 03:10 PM
Bigprfed22's Avatar
Bigprfed22
lol Pics or it didnt happen!
donniedarko
Oct 21, 2015 01:15 PM
molala
Oct 2, 2015 01:53 PM
one73ronin
23
Sep 22, 2015 09:56 AM
rob76turbo
Sep 15, 2015 10:11 AM
Ryan Caballo
Sep 4, 2015 12:20 PM
