R50/53 Can you tell me what this light is called, & how to replace it?
Old Dec 29, 2011 | 06:52 PM
Hedjuk's Avatar
Hedjuk
If you are facing the front of a R50 Mini, there are three sets of lights: headlight, middle round light with two bulbs, and finally the precut circle for fog lights. The light in question is the middle light, which the assembly has two lights: half of the assembly is orange and has a bulb roughly the size of a quarter, and the second bulb is much smaller and is white. The bulb on the left side of the assembly is out, and seems to be a "driving" light maybe? The bulb on the right of the assembly and is covered in orange, can be twisted and then replaced. The left light, the white one, only has a wiring connection you can pull-out, but no obvious way to get to the bulb.
Attached are two photos showing the location of the bulb in question, as well as the light socket where the bulb is located. Can you tell me what is this specific bulb in question, and how to get to it?
Attached Thumbnails Can you tell me what this light is called, & how to replace it?-photo-1.jpg   Can you tell me what this light is called, & how to replace it?-photo.jpg
Old Dec 29, 2011 | 06:54 PM
hunter99's Avatar
hunter99
I believe you are referring to the parking light.
Old Dec 29, 2011 | 08:54 PM
minitoo's Avatar
minitoo
2003 Owner's Manual page 108 says just turn the housing to the left and remove. 5w bulb.
Old Dec 30, 2011 | 01:12 PM
ofioliti's Avatar
ofioliti
I replaced mine several years ago and if I remember correctly it was hard to get to even with my small hands. I used long-nosed pliers. Grasp and twist GENTLY or you might break the plastic housing. Good luck!
Old Dec 30, 2011 | 02:13 PM
BlwnAway's Avatar
BlwnAway
Yes, that is the parking light and it can be tight, just twist, firmly and carefully. It's a standard 194 bulb (american # for the autoparts store)
Old Jan 16, 2012 | 10:49 PM
diesel_caddy's Avatar
diesel_caddy
I just did this on my mini. Just use a pair of pliers and turn counter-clockwise.
Good luck!
Old Jan 17, 2012 | 06:25 AM
domchj46's Avatar
domchj46
I just replaced mine as well. Turn it to unlock it.
Old Jan 18, 2012 | 07:14 PM
sbarr9's Avatar
sbarr9
Yeah, those are the parking lights, and mine works intermittently. I am going to try to tighten it tomorrow, because if it doesn't work when I first turn it on, I can walk by and tap it, and it will turn on.
Old Jan 19, 2012 | 03:07 AM
camminich's Avatar
camminich
And while yrou are there, if you are feeling adventurous replace your yellow turn single bulbs with the silver star upgrade. Cost isn't bad, and it gets rid of the yellow look in that lens.
Old Sep 4, 2013 | 02:40 PM
Dave Pevsner's Avatar
Dave Pevsner
that housing has both a parking light and a turn signal. on my car, the right-side parking light was dead, and my uncle ripped the old one out and put a new one in, took him 10 seconds.
stevepsd
35
Dec 6, 2022 03:22 PM
eliseo1981
Jan 28, 2021 02:45 PM
kpl
Aug 11, 2015 04:52 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
