School me on TPMS and wheel swapping
Old Dec 26, 2011 | 07:59 AM
danigurrl's Avatar
danigurrl
I bought a set of winter wheels and snow tires and TPMS (just the TPMS are from tirerack.com, the wheels are used-OEM.)
I need to get the tires put on the wheels (non-RF snow tires). Do I have to go to the dealer to have the TPMS programmed? And, when I swap back to the summer wheels/tires (that came on the car), do I have to get those TPMS reprogrammed again by the dealer?
My friend's shop can install my snows on wheels and he can install the tirerack TPMS in the tires, but he said he can't program the TPMS to the car.
Old Dec 26, 2011 | 08:14 AM
rhawth99's Avatar
rhawth99
I'm pretty sure that the only thing that will need to be done after you put the new tires/wheels on the car is to reset the TPMS following the procedure in your owner's manual. Since you purchased the TPMS from tirerack, they will be the correct ones for the MINI.
Old Dec 26, 2011 | 08:56 AM
yetti96's Avatar
yetti96
Ensure they are the newest version as the sensors changed frequencies in 2009 I think.
Once the sensors are in the wheels, swap at your own free will. You just have to reset them through the end of the stalk every time you do so, no biggie.
Old Dec 26, 2011 | 09:26 AM
danigurrl's Avatar
danigurrl
That's all good news. The TPMS should be correct because I called tirerack to verify that they would be the correct ones, so they aren't the older version.
Old Dec 26, 2011 | 10:34 AM
Hawkeye's Avatar
Hawkeye
As an owner of a March 2009 built Clubby, I can attest that MINI changed TPMS modules in October 2009. Now, there may have been a change since then but, if not, you/we must assume that Tire Rack sold you the correct edition. Reseting them is very easy as already described.
Old Dec 28, 2011 | 01:31 PM
drsimmons's Avatar
drsimmons
After I installed my wheels and tires (from TireRack) I didn't have to do anything. The TPMS recognized them (or whatever it does) and it's been fine since. Put them on back in Sept.
In fact, just ordered another wheel and tire from same place as spare. I ate a big ole' screw this morning in my left rear.
Had it fixed and the tire monitor went off after correct pressure was in tire.
At least I know they work. Little picture with an arrow pointing to left rear tire.
Getrieben
Sep 12, 2024 07:03 AM
Kimolaoha
Dec 5, 2020 09:32 PM
ebowling
90
Aug 4, 2019 09:15 AM
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
