ABS malfunctions
Old Feb 20, 2004 | 05:39 PM
talent7's Avatar
talent7
I have a '04 NMS with less than 1000 miles on it. At about 200 miles I experienced what I would call asymmetric braking from the front brakes...it pulled so hard it almost took the wheel out of my hand. I thought I might have been on an icy patch, but it has happened three more times, each time on dry surfaces, either pulling to the left or right, usually at braking from a top speed no greater than 35 mph since the previous complete stop. The pulling could send me off the road if I hadn't had both hands on the wheel. NO ABS warning light illuminates in the cockpit.
Has anyone ever heard of this before?
Old Feb 20, 2004 | 07:25 PM
Trippy's Avatar
Trippy
It's broken. Take it to the dealer immediately before you are hurt,
or you hurt someone.
If you kill a kid on a bycycle because of this, you'll feel really bad
and we'll feel bad right there with yuo.
Don't fool around with broken brakes. Fix them right now.
Old Feb 20, 2004 | 07:47 PM
GBMINI's Avatar
GBMINI
If you don't feel the pulsing brake pedal, it is not an ABS issue - however it *IS* an issue with the brakes; maybe a problem with a loose or damaged pad, or air in the lines.
Whatever, like trippy says - get it fixed!
Old Apr 10, 2004 | 08:16 PM
talent7's Avatar
talent7
Complete brake and computer DME download inspection indicates all systems A-OK. Braking pull is now just slightly noticable with 2500 miles on car...suspect new pad seating/mating with disk was all it was...but boy oh boy was it a strong pull of center. Maybe it's the nature of this cars rack and pinion feedback. I've owned about 17 cars now, and the only car I've owned (other than a '67 mini 850) that even came close to the feel of driving this NMS was my 1979 Saab 99 turbo. That car had a close ratio 4-speed and MANUAL rack & pinion steering.
Finhead
Electrical
Apr 12, 2019 04:05 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
kbadaloni
Sep 20, 2015 12:56 PM
gzaos
Sep 14, 2015 04:21 AM
