R56 Transmisson Bad on R56 only 42K Miles? What's with that?
Old Dec 21, 2011 | 09:18 PM
TKA's Avatar
TKA
Mechanic said transmission on 07 R56 S 6 speed, going bad at 42K miles. Only 5 months after warranty. First car I have ever had with a transmission go bad in that period of time. Taking to dealer on Monday. Any body else had similar problems. Can't believe this!
Old Dec 21, 2011 | 09:46 PM
cereal's Avatar
cereal
I'm assuming you mean that the clutch is going. It isn't the first thread I've seen on the forums about the clutch on MINI's going early. I'm sure if you search the R56 forums you can find a few threads that had clutches going. I agree that it seems to be quite a bit early.
However, I do wonder how many of those that have clutches go this early are partially if not entirely at fault or if it is a malfunction of the original clutch/transmission design. I'm not pointing fingers and everyone will tell you they drive a manual perfectly (I naturally do too). In my opinion either the MINI is trickier to drive properly or the clutches go faster than other vehicles given the high rate of threads regarding this, or am I seeing this wrong? Maybe someone else can correct me?
Old Dec 22, 2011 | 12:58 AM
Oakland Raiders Mini's Avatar
I have an 07 R56 S 6 speed also. My brother & I both learned how to drive manual on this car & it's at 57,xxx miles right now.I don't drive drunk so 1 night I let my friend drive me home & he had the hand brake on four at least 3 miles . I don't have any other references of any other cars but I drive the hell out of my car at 26.1 mpg.
Old Dec 22, 2011 | 04:18 AM
yetti96's Avatar
yetti96
Not common for the 6 speed getrag or the Aisin auto (wasn't originally specified)
Old Dec 22, 2011 | 07:19 AM
cmt52663's Avatar
cmt52663
err... does that mean that the gearbox is developing a taste for cigars, fast women and whisky? what does "going bad" mean in a bit more detail please?
Old Dec 22, 2011 | 09:07 AM
TKA's Avatar
TKA
Gertag 6 - N14 engine - Noise at 1st, 2nd, and 3rd gear. Release point on clutch pedal has not change, no slippage, only chatter in first three gears. Noise starts after clutch engagement in 1st gear, 2nd gear, and starts to trail off in 3rd gear!. 4th, 5th, 6th are fine. It appears in higher gears only. Down shift to 3rd, and 2nd quite loud and noisy.
Old Dec 22, 2011 | 09:17 AM
Bmont82's Avatar
Bmont82
With the car in neutral and fully stopped is it noisy and does it go away when pushing the clutch pedal?
Old Dec 23, 2011 | 06:34 AM
TKA's Avatar
TKA
No noise fully stopped in neutral. Also, no noise with clutch pedal depressed. Noise is at point of release through acceleration and through the high gears 2nd and 3rd. At 4th gear the noise subsides. Down shifting to second gear sounds terrible. Even reverse rattles during engagement and acceleration. Had Way at Way Motor works confirm (that guy is awesome).
Old Dec 23, 2011 | 03:18 PM
TKA's Avatar
TKA
No noise sitting still in neutral. And yes the noise goes away when the clutch is pressed in. The noise occurs in the high gears (1,2,3). 4th gear the noise goes away.
Thanks for the response.
Old Dec 23, 2011 | 06:43 PM
Slave to Felines's Avatar
Slave to Felines
Sounds like either a throwout bearing or an input shaft bearing. Bummer.
Old Dec 25, 2011 | 11:20 AM
PeteinLongBeach's Avatar
PeteinLongBeach
How do you figure?? TKA said NO noise sitting in neutral (input bearing would make noise) and NO noise when clutch is depressed (throwout bearing would make noise)
Old Dec 26, 2011 | 01:00 PM
TKA's Avatar
TKA
As two non-dealer mechanics indicated Tranny gone.
Took to dealer this morning. These guys diagnosed as Differential Noise, Release Bearing Noise. Recommended replacement of transmission, clutch, pressure plate, throwout bearing, and flywheel @ 43K miles!!!!!! Labor included around $7. I left quickly.
Any suggestions on where to purchase Re manufactured Transmission at decent price?
Old Dec 26, 2011 | 07:43 PM
Marioalex24's Avatar
Marioalex24
Wow $7k sounds alot.
Old Dec 26, 2011 | 08:05 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes 7k is ALOT
but the trans is working, just makes noise. I suggest driving it till it gets worse as this isn't going to be cheap.
Old Dec 27, 2011 | 06:18 AM
highlander709's Avatar
highlander709
To OP, are you original owner of vehicle? I am guessing not.
Old Dec 27, 2011 | 08:32 AM
Scooter162's Avatar
Scooter162
I would try to see if your dealer would work with mini on that. I have a 07 MCSa where the tran. conrtrol unit went out at 3k or about 5 month out of warranty and my dealer got them to grace the repair. That was about 4 grand. It took about 3 weeks to get the work done because of the wait to get the OK from Mini and I was not offered a loaner.
Old Jan 6, 2012 | 08:09 AM
TKA's Avatar
TKA
Yes, I am the only owner of the vehicle. And I am woking with Mini and the dealer to hopefully grace the repair. Hope hear something back today.
Thanks for all of the comments.
Old Jan 6, 2012 | 08:53 AM
b13mini's Avatar
b13mini
Keep us updated!!
Old Jan 6, 2012 | 06:01 PM
Govtslug's Avatar
Govtslug
Here's a place just north of Charlotte, NC that has an almost new 2009 MCS 6 speed for sale. They convert cars into electrics and sell the engines and tranny's.
http://charlotte.craigslist.org/pts/2687948424.html
Tom.
Zettinger
Aug 25, 2015 04:04 PM
elightbo
Aug 17, 2015 01:50 PM
Aug 12, 2015 01:24 PM
marendt428
Aug 8, 2015 04:44 AM
