R56 brake fluid
Old Dec 21, 2011 | 09:03 PM
sLy201's Avatar
sLy201
brake fluid
I am not a mechanically inclined person but i have a question regarding brake fluid. How do you know when to change your brake fluid and is it something as easy as an oil change? If it is easy as an oil change what type of brake fluid do you recommend for a 2011 R56 ?? Thanks a lot
Old Dec 21, 2011 | 10:33 PM
Slave to Felines's Avatar
Slave to Felines
You know by the calendar. Every other year, change it out. Brake fluid absorbs water from the air, and the water slowly accumulates. It degrades the heat absorption power of the fluid, and it will eventually rust the inside of the brake parts. Not good.
It is changed by pretty much bleeding the brakes until the fluid coming out of the bleeder is new fluid.
Old Dec 22, 2011 | 03:29 AM
JAB 67's Avatar
JAB 67
If you're not 'mechanically inclined' perhaps this is a job best left to someone who is.
Old Dec 22, 2011 | 04:10 AM
yetti96's Avatar
yetti96
Luckily the 1st one is covered by MINI. The OBC tells you the date (every 2 years) when to change it.
Old Jan 10, 2012 | 08:56 PM
Benibiker's Avatar
Benibiker
I just got the service warning for the brake fluid flush, it'll be $250 and add another $200 to do a maintenance scope and basically reset the indicator... Am I about to get to get ripped off?
Old Jan 11, 2012 | 04:35 AM
richardsperry's Avatar
richardsperry
Like everybody has said. every 2 years, or before you go to the track.'
BUT DAMN! $250 to do a brake fluid flush?
If your car is out of warranty, why on earth would you take it the most expensive service option? (the dealer?)
Old Jan 11, 2012 | 05:52 AM
synzeus's Avatar
synzeus
No you re not getting ripped off.. I think that this is more appropriate:
I paid 15€ for the brake fluid and its installation.
Old Jan 11, 2012 | 06:03 AM
muzak's Avatar
muzak
Just the $250 wouldn't be that bad. But, $450 total? No thanks. It's easy to do yourself if you have some time. Spend a small fraction of that and get yourself a bleeding kit with the pump that you'll have available for future usage as well. Otherwise, I'd call around to some independent shops to compare and you can reset the indicator yourself.
Old Jan 11, 2012 | 06:26 AM
jhowla's Avatar
jhowla
$250 for a brake flush? Are you serious?
I think $250 for a brake flush is a bit steep unless there is something else wrong woth your system. Almost any shop can do it and the most I have been quoted was $180 at the dealer. The other shop I use charges $80. If you haven't already, go get a second opinion from another shop.
Old Jan 11, 2012 | 08:38 PM
Benibiker's Avatar
Benibiker
This is from the Mini service dept of course, who else would charge that much . There's nothing wrong with my brakes, just time to flush the fluid according to the OBC.
Last edited by Benibiker; Jan 11, 2012 at 08:59 PM. Reason: Found how to reset the warning light.
Old Jan 11, 2012 | 09:29 PM
Benibiker's Avatar
Benibiker
So if I'm still under warranty (23,000 miles/3 years 4 months) do I need to take it to or is it recommended I take it to Mini for the flush?
Old Jan 11, 2012 | 09:42 PM
Btwyx's Avatar
Btwyx
I get brake flushes for $125 from an independent BMW/MINI shop.
Old Jan 12, 2012 | 01:17 AM
jhowla's Avatar
jhowla
Brake flush
Should be as simple as a phone call. If your dealer will do if for free under warranty take it to the dealer. If not, take it to an independent shop. Having routine maintenance done at another shop does not affect the validity of your dealer warranty.
Old Jan 12, 2012 | 05:34 AM
jcauseyfd's Avatar
jcauseyfd
Flushing the brakes is not a warranty item, it is maintenance. At 3 years, 4 months, you are beyond the 36 month included maintenance plan.
Old Jan 12, 2012 | 09:12 PM
Benibiker's Avatar
Benibiker
Thanks, that was my question, whether going to another shop would invalidate my remaining dealer warranty. I'll make some calls...
Old Jan 13, 2012 | 08:40 AM
AAONMS's Avatar
AAONMS
My 2¢:
Typically, I flush the brake system annually and bleed before a trip to the Dragon.
Had MINI do a quick bleed last fall before MSSD.
When considering brand and type of brake fluid to purchase, some things to consider:
Dry boiling point
Wet boiling point
Higher is better.
On previous cars, I used Castrol LMA or Ford Heavy Duty Brake Fluid.
Ford was when I was autocross/racing and if I planned to frequently bleed the system.
Castrol LMA if I was not going to be bleeding on a short time cycle.
Be careful to not max conventional (Dot 3 and DOT 4) and silicone type (DOT 5) fluids.
Old Jan 13, 2012 | 07:20 PM
Maugre's Avatar
Maugre
He means DO NOT MIX. Conventional and silicone do not like each other.
Old Jan 13, 2012 | 07:40 PM
Slave to Felines
Or just don't use the silicone crap.
Old Jan 13, 2012 | 09:31 PM
1bigpea's Avatar
1bigpea
Yeah, you're getting taken by the dealership big time. A brake fluid flush is easy, and easier if you have 2 people. If you bleed your own brakes you learn a lot about your vehicle and can do your own inspections. $200 to reset the indicator or computer? Ouch!
If you want to flush your brake fluid yourself and do it every year or so then check out the Motive Power Bleeder...I use it on my FJ and multiple other vehicles including my wife's 2011 MCS, and I'll use it on my Countryman too. It's paid for itself a few times over already.
http://motiveproducts.3dcartstores.com/
/plug
Old Oct 21, 2012 | 02:34 PM
MiniMoic's Avatar
MiniMoic
So Im taking this back from the dead.
Just got my 3rd mini cooper, previous two were automatic. Since I do like 10 track days a year, first thing to do---to change brake fluid. I took the car to a small shop recenlty open near my house and asked them to do it. They started to pump out the fluid from the resourvouir with a small pumo. My face was like this:
Any way, I let them finish the bleed, but now I hear a very soft but noticeable hiss when the clutch pedal is not enganged. It goes away when I press a litle bit the pedal...
I wonder if i got air in the clutch line...
Old Oct 21, 2012 | 07:22 PM
1bigpea's Avatar
1bigpea
Most definitely you do....
Old Oct 22, 2012 | 05:49 AM
MiniMoic's Avatar
MiniMoic
Yeah, somehow I knew, I mean it makes sense as its the only thing that changed in the car, and if they took away all the fluid without bleeding the clutch line, it will have air.
Now, whats the physics behind the noise? Why it will make this hiss only above 2k revs and will stop after i press a litle bit the clutch pedal?
molala
Oct 2, 2015 01:53 PM
Gremothra
Sep 9, 2015 08:42 PM
Sep 3, 2015 03:01 PM
Sep 3, 2015 02:06 PM
Ntety
Sep 2, 2015 08:39 PM
