Suspension Most awesome track coilovers - Custom PSS9 or KW Clubsport
Old Dec 13, 2011 | 12:52 PM
BruceWarne's Avatar
BruceWarne
Hi
I bought some PSS9 from a fellow NAM'er...turns out the rear ones are bent and I need to have them rebuilt (I'm sure the seller was unaware of this).
So, what would make the best track setup:
PSS9, custom valved for 400lb/in (front) 500lb/in(rear)
KW Clubsport off-the-shelf (455 lb/in all around).
The KW's would have to be really good to beat the 100% price difference compared with rebuilidng/valving PSS9 and adding some Swift springs.
I'm on NT01's, control arms, front/rear swaybars, etc etc.
Opinions?
Old Dec 14, 2011 | 06:54 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I've had the PSS9s on my R53 for a long time, they work well. The next car I build I'm using a custom set of KW's on.
If you want the KW's let me know I'll fix you up, if it's still a street car you should consider our TSW setup KW's as they will be great dual purpose.
Old Dec 14, 2011 | 11:17 PM
ThatMiNiGuy's Avatar
ThatMiNiGuy
Custom PSS9 since you have them already and can make them perfect.
Though if you scrap that idea then KW V3.
http://www.waymotorworks.com/kw-vari...r50-52-53.html
Old Dec 15, 2011 | 04:54 AM
THE ITCH's Avatar
THE ITCH
BruceWarne
Would you mind sharing the cost to rebuild/revalve the PSS9's and where you would be having that done should you go that route?
Thanks, Steve
[QUOTE=BruceWarne;3415327]Hi
Apr 7, 2020 06:49 PM
molala
Oct 2, 2015 01:53 PM
RIchard Nguyen
Sep 6, 2015 07:21 PM
Ryan Caballo
Sep 4, 2015 12:20 PM
Sep 4, 2015 09:23 AM
