R56 Burping the Coolant System
Old Dec 7, 2011 | 07:44 PM
trwxxa's Avatar
trwxxa
Does anybody have the service manual instructions for getting trapped air out of the cooling system?
I'm going to put a "Hotlink" adapter in the coolant line, and I know some air is going to get in. Just want to know MINI's method for burping the system.
Old Dec 8, 2011 | 06:19 AM
bluefox280's Avatar
bluefox280
Directions per the Bentley Service Manual:
R56 Coolant System - Filling and Bleeding (without Vacuum Bleeder)
- Before filling radiator:
* switch ignition ON - do NOT start engine
* set heater temperature control to full warm
* set blower control to low
* set set heater control (if installed) to maximum
- Start engine and run at idle speed for one minute (coolant reservoir cap open). Adjust coolant level to MAX level, and close cap.
- Run engine until it reaches operating temperature.
- After engine has cooled, recheck coolant level.
- Top up so that coolant level is at MAX.
- If trapped air cannot be bled manually, pressure-bleed system using cooling system vacuum bleeder.
- Erik
Old Dec 8, 2011 | 02:09 PM
trwxxa's Avatar
trwxxa
That's what I was looking for!
Thanks, Erik!
Old Dec 8, 2011 | 09:55 PM
Minidrivr's Avatar
Minidrivr
According to the factory manual you need to open the bleeder on the thermostat housing. See my post #5 in this thread.
https://www.northamericanmotoring.com/forums/stock-problems-issues/220365-replaced-coolant-temp-sensor-cant-get-system-to-bleed.html
Old Dec 8, 2011 | 11:12 PM
trwxxa's Avatar
trwxxa
Thanks, Minidrivr! That'll be a great help too.
Filmy
Sep 7, 2015 08:27 PM
jesterofatlas
Sep 4, 2015 11:23 PM
mimaal
Sep 4, 2015 09:09 AM
M7Speed
R58 :: Coupé Talk (2012+)
Sep 3, 2015 07:29 AM
M7Speed
Sep 3, 2015 07:27 AM
