R50/53 Anyone elses TA bearing look like this?
Old Dec 3, 2011 | 02:14 PM
SniperDetailing's Avatar
SniperDetailing
So the other week I was just driving along and all of a sudden my clutch pedal starts acting funny, almost like it wasn't actually doing anything to the pressure plate. Next thing I know I'm trying to pull away from an intersection and I can't engage any gears. Push the clutch to the floor and nothing, almost as if I was trying to select first without clutching in at all. Then when I finally got it home it starting making a horrible screeching noises with the clutch pedal depressed. So I went ahead and removed the transmission to take a look. Now I figured maybe my TO bearing had gone a little bit like a lot seem to do, or at the worst my pressure plate had failed. Needless to say, I am glad it wasn't the pressure plate (I'm going to replace the flywheel clutch and pp anyways since I'm in there), but I was pretty surprised how ****ed the throwout bearing actually was.
Last edited by SniperDetailing; Dec 3, 2011 at 02:16 PM. Reason: Throwout**** not TA
Old Dec 3, 2011 | 02:27 PM
JAB 67's Avatar
JAB 67
How many miles?
Old Dec 3, 2011 | 02:28 PM
SniperDetailing
Originally Posted by JAB 67
How many miles?
just a hair over 93K
Old Dec 3, 2011 | 03:20 PM
Professor's Avatar
Professor
Seen several go out like that.
Old Dec 7, 2011 | 12:07 PM
mantysman's Avatar
mantysman
Mine looked like that at about 103,000
Chinsy throwout bearing, real flimsy piece of shyte. It cost me @$900.00 for a local yokel to replace it (and the almost pristine clutch while he was at it).
Old Dec 7, 2011 | 01:09 PM
JAB 67's Avatar
JAB 67
Sniper: How much did it cost you to replace it?
Old Dec 7, 2011 | 01:42 PM
SniperDetailing
I'm doing the work on my own in my garage, so labor is $0, but while I'm in there I'm upgrading to a Fidanza lightweight flywheel, Spec Stage 1 sprung clutch kit, new flywheel stretch bolts and I'm replacing the throwout bearing guide tube since mine is a little beat up and rather than risking it not working and having to tear it all down again I'm just going to spend the $45 to replace it. So I think when all said and done it's like $750 or so when you shop around.
Old Dec 7, 2011 | 10:28 PM
valvashon's Avatar
valvashon
My wife's '03 R50 TO bearing looked a lot like that when it went out at about 83k or so earlier in the summer. Same symptoms with the problems shifting and screeching and all. We were 300+ miles away from home on day 2 of a PSMINI weekend drive that we hosted when it started making noise on the "visiting wineries" portion of the drive late on a Sunday afternoon. Earlier in the day there had been a "spirited driving" portion, but we don't think that had anything to do with it.
Went from working perfectly to being completely unable to shift out of gear in 4 hours. Thought I had a picture but I think I actually have the TO bearing in the garage. Our pressure plate fingers showed signs of excessive heat and I do have pictures of that. Will post some tomorrow when I take one of the TO bearing. mantysman got a deal at $900; we dropped 2 large and then some.
Val
Old Dec 7, 2011 | 11:57 PM
JAB 67's Avatar
JAB 67
Whenever I see that someone has paid $1000 or more just in labor to do a clutch or throw-out bearing job I think back to a conversation I recently had with someone who worked as a mechanic in one of the local MINI dealerships but left to open his own shop. He told me that one day he and a fellow mechanic had a race to see who could do a clutch job the fastest. Starting with the car on the lift, each could do the complete job in 50 minutes or less!!
Old Dec 10, 2011 | 10:39 AM
Skot53's Avatar
Skot53
That's encouraging.
My TO bearing makes noise pulling away from stops when it's cold. If it's not covered under Powertrain warranty (aftermarket, purchased when I bought the car), than I'll be doing it myself. I'm a non-automotive mechanic by trade, so it should be interesting, to say the least.
Supertractor3
Apr 7, 2017 11:16 AM
QuickCooper
Dec 29, 2016 06:46 PM
pfcmooney
Jun 15, 2016 07:22 PM
Sep 3, 2015 02:06 PM
Sep 3, 2015 10:29 AM
