R50/53 The letters " E P " under the mileage ?
Old Nov 22, 2011 | 05:03 PM
MiniKar's Avatar
MiniKar
Has anyone ever seen this on their Mini S or do you know what it means.
The letters " E P " are now under the mileage and service engine soon light is now on.
How do I clear this code ???
Thanks, MiniKar
Old Nov 25, 2011 | 06:50 PM
MiniKar's Avatar
MiniKar
For those interested, this resulted from installing a defective Sprint Booster. The EP appeared under the mileage readout, the Service engine soon light came on, and overall many error codes poped up.
I used the OBD code reader and to reset the service mileage, and to clear the codes and turn off the Service engine light. All is back to normal now.
I am getting a new Sprint Booster and will try the install once again; If the second unit is defective I won't be trying a third time !
Old Nov 25, 2011 | 06:55 PM
rustyeuro's Avatar
rustyeuro
how would you explain that showing up before a sprint booster unit was installed?
Old Nov 25, 2011 | 07:31 PM
MiniKar's Avatar
MiniKar
If you take a look above, I had just installed a Sprint Booster that was defective and the result was the EP, various codes, and the Service Engine light. Its all back to normal now.
I contacted Mini Mania about the codes and the EP and they said " I guess you got a defective unit " Hum . . . . . . . ? ? ?
Old Nov 26, 2011 | 01:12 PM
mini_macky's Avatar
mini_macky
Do you by any chance have a MCSa? On my former R50 CVT, I remember seeing "EP" & IIRC it's related to the transmission
Old Nov 26, 2011 | 10:18 PM
rustyeuro's Avatar
rustyeuro
great... i've been rocking a airbag warning light and EP warning light for about 3 days now...
Old Nov 27, 2011 | 07:16 AM
ZippyNH's Avatar
ZippyNH
Thanks, MiniKar
Since the ep is only used on the cvt to my knowledge, the explanation that a defective sprint booster turned it on, and the fact removing it fixed it seems to make sense.
It is sometimes interesting how seeming unrelated things (the unused ep and a sprintbooster) can interact....guess with the electronic busses used for communications, a stray siginal can do lots of things...
The ep on a CVT is a bad thing....
on an S it certainly is a curiosity....
Old Nov 27, 2011 | 09:07 AM
rustyeuro's Avatar
rustyeuro
well, i'll try to pull my sprint booster sometime this week and let you know if it clears the code
Old Nov 27, 2011 | 06:30 PM
MiniKar's Avatar
MiniKar
To clear the code EP, I used a code reader to see all the error codes which we're related to the transmission. After clearing all the error codes twice and starting the car twice, the error EP and Service Engine light went away .................................
So by just disconnecting the Sprint Booster that did not clear up anything .
Old Nov 28, 2011 | 06:14 AM
valvashon's Avatar
valvashon
If you have certain build dates of '02 and '03 models, there can be a failure in the airbag deploying system that can trigger the airbag warning light. The warranty was extended for this problem to 10 years and a certain mileage. You might want to have this checked out at the dealer; they replaced lots of things and took care of this for me for free. Hurry, the warranty time is running out.
Val
https://www.northamericanmotoring.co...003-minis.html
Last edited by valvashon; Nov 28, 2011 at 06:24 AM. Reason: added url of previous post
Old Nov 28, 2011 | 08:50 AM
rustyeuro's Avatar
rustyeuro
I'm not the original owner of the car and i already have 113K on the odometer. i'm almost certain they're not going to good will this one in.
Old Nov 28, 2011 | 02:18 PM
valvashon's Avatar
valvashon
No- follow the link above and the follow the "minicooperproblems" link. It's not a goodwill sort of thing, it's a warranty issue. If you fall under the build date and you have that specific problem, theyhave to fix it.
Val
Old Nov 28, 2011 | 09:41 PM
rustyeuro's Avatar
rustyeuro
printed off NHTSA action numbers
madmix
Oct 5, 2015 09:58 AM
Alpha Motoring
Oct 1, 2015 10:30 AM
MiniTigger
Sep 23, 2015 09:17 AM
