Timing Chain Tensioner Measurements
Old Oct 21, 2011 | 04:16 PM
KochDeutsch's Avatar
KochDeutsch
Does anyone know where I can find measurements of an R56 timing chain tensioner? I'm looking to machine a tool to measure the chain distance.
Or if you have one laying around and could send it to me, I'd be very thankful.
Old May 28, 2012 | 03:40 AM
Hubs's Avatar
Hubs
How do you measure the chain tensioner ? Is there a special tool? What are the correct measurements ?
Old May 28, 2012 | 07:02 AM
jcauseyfd's Avatar
jcauseyfd
To measure the chain, you use a tool like this:
http://www.ntxtools.com/Merchant/mer...&Store_Code=01
Put that in where the tensioner goes, tighten it down to some very small torque number (basically as soon as the chain is tight), take the tool out and measure. If the measurement is more than like 68 mm, you should replace the chain.
* note - workin off memory - verify numbers with appropriate sources. Just trying to explain the concept.
Old May 28, 2012 | 12:14 PM
Hubs's Avatar
Hubs
Measurement
Is this where you would read the measurement ?
09R56
Nov 16, 2022 10:49 AM
Melvinyip
Apr 17, 2020 09:28 AM
TREX
Nov 2, 2019 07:31 PM
alistaircookie
Oct 8, 2015 10:52 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
