R50/53 Power steering fluid
Old Oct 17, 2011 | 09:11 AM
jimaikin's Avatar
jimaikin
Just wondering if there are other options of fluid available not at the dealer to top off the PS fluid level?
Thanks for the input
Old Oct 17, 2011 | 12:33 PM
jimaikin's Avatar
jimaikin
Just noticed the manual doesn't even label the power steering cap in the engine compartment diagram as a location for maintenance. Is it assumed that you never look at the PS fluid level? I'm assuming it is the small reservoir & cap right next to the coolant expansion tank?
Old Oct 17, 2011 | 01:57 PM
kazlot's Avatar
kazlot
Yes that's the power steering reservoir.
Unless you have a leak you should not have to top it off.
As an example I have not touched mine, other than to check, for 50,000 miles.
Since you have a first gen car Pentosin CHF 11s is the proper fluid for the power steering.
I have no idea as to the availability or suitability of other fluids for you to use.
Hope this helps...
HaveATank
Sep 4, 2015 08:04 AM
Aug 25, 2015 09:33 AM
coachvminis
Aug 25, 2015 06:58 AM
HaveATank
Aug 24, 2015 10:26 AM
minipopkart
Aug 13, 2015 05:22 AM
