Suspension Ordered control arm bushings
Old Sep 21, 2011 | 07:13 PM
niquemarshall's Avatar
niquemarshall
So i ordered Powerflex CABs for the front as a kit prepressed into brackets.. Any pointers or hints i should know about?
PS.. Also noticed the brake fluid was brown, as in slightly used motor oil, is it supposed to be this way?
Old Sep 22, 2011 | 06:47 AM
carramrod's Avatar
carramrod
I'd like to hear your impressions of the Powerflex when you get them in.
The brake fluid (assuming stock fluid) should be clear-ish. Over time it will get brown, but it should be changed semi-regularly like every 3 years unless you've boiled it or something (or do track days).
Old Sep 22, 2011 | 07:23 AM
niquemarshall
I hear that the poly bushings are where its at so ill post my opinion (if I remember LOL)
But yea my brake fluid is the same color as soy sauce... Is it time for a flush?
Old Sep 28, 2011 | 08:55 AM
carramrod's Avatar
carramrod
Just checking if you've installed them yet.
Yes, soy sauce is usually time to change.
Old Sep 28, 2011 | 09:36 AM
niquemarshall
Well I attempted to over the weekend and failed miserably by myself.. I'll have toget with a buddy of mine who can help..
Old Sep 28, 2011 | 09:39 AM
carramrod's Avatar
carramrod
Yea, I kinda think I'm gonna get it done at a shop. At least rent a lift or something, hahah
Old Sep 29, 2011 | 08:29 AM
Gizmo's Avatar
Gizmo
The bushings do help a lot.
BUT, when you get the pre-pressed bushings you must lower the subframe to get the old brackets out and new ones in.
I ended up just bring the car to my mechanic to do it and it took him a bit to get them in since the bolts are a ***** to get off.
Old Oct 17, 2011 | 08:56 AM
niquemarshall
I finally got them installed, and man its a night and day difference! The wheels dont spin wildly under full throttle, the shifter and clutch are a LOT smoother and since i also replaced my rack, it drives in a straight line now (mine was bad) Now for that alignment.....
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
maestro39
Oct 27, 2015 02:38 PM
JPMontes3
Aug 23, 2015 01:26 AM
Minibeagle
Aug 13, 2015 10:00 AM
