Interior/Exterior Carbon Fiber mounting bracket advice.
Old Sep 13, 2011 | 07:03 PM
Agarwaen's Avatar
Agarwaen
I have a custom made Carbon Fiber hood scoop that I bought off a fellow NAMer. Just recently had 3 of the mounting tabs break off at the mounting point. No damage was done to either surface. I have never worked with Carbon before, Is there any special epoxy or method I should use to reattach these?
Old Sep 13, 2011 | 07:30 PM
Buli's Avatar
Buli
I would clean the mounts and scoop then use 1 hour set time epoxy. Don't use the 5 minute epoxy it is brittle.
Old Sep 13, 2011 | 07:39 PM
Hillis24's Avatar
Hillis24
some epoxies are not compatible with each other. It might be a good idea to contact the person you purchased it from and find out which type of epoxy was used to create the piece. Just so it doesn't come off again.
Old Sep 14, 2011 | 06:47 AM
anitan1's Avatar
anitan1
It may seem too "low tech" but Liquid Nails would hold it extremely well and it's viscous enough that it would interdigitate with the holes on the clip well. Plus, it's fairly inert (as epoxies go) so there's low risk of it damaging the CF part.
Old Sep 14, 2011 | 06:01 PM
Dedbeat0321's Avatar
Dedbeat0321
JB weld
techgearpro
Jul 23, 2019 07:09 PM
bavmotors
Oct 13, 2015 12:43 PM
ptbster
Sep 13, 2015 07:22 AM
F55MidnightBlackCooperS
Sep 3, 2015 04:02 PM
Ntety
Sep 2, 2015 08:39 PM
